  New Posts New Posts RSS Feed - Changing from a Holly 4 barrell to EFI
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Topic: Changing from a Holly 4 barrell to EFI
    Posted: November-06-2018 at 2:39pm
Originally posted by skierbrant skierbrant wrote:
What sparked my interest in changing over to EFI was cost. I was talking with a car guy at my work. For a car, the cost is fairly inexpensive ($370 ish). SkierOx had given me the name of a company in Eau Claire, Wisconsin called Bigs Performance Products to get my Holy 4 barrel rebuilt. The cost he quoted me on the phone was $245 - $295 for the rebuild. If I could get a little better HP (not that I need it), I would give it a shot. I can't see spending $2300 to upgrade. I'd rather spend $9800 and put a new PCM 343 HP EX-343 engine in. So, I'm either going to buy the rebuild kit for $40 and rebuild the carb myself, or send it to Bigs Performance.
thats just for the throttle body, no injectors, harness, nor electronics
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75 Tique Quote  Post ReplyReply Direct Link To This Post Posted: November-06-2018 at 11:37am
Originally posted by Donald80SN Donald80SN wrote:
   I do believe I have a rare National or Regional Tow Boat.
Donald,
I shouldnt have to remind you that just because it says "National or Regional Tow Boat" on the side, doesnt mean it was actually used to tow boats at sanctioned events.
Now if it has the super reinforced rear lifting ring that can handle a 12,000 pound horizontal load without cracking the gel, then it just might be an official "National or Regional Tow Boat"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Donald80SN Quote  Post ReplyReply Direct Link To This Post Posted: November-06-2018 at 11:17am
Gary,
You have it backwards. Getting towed, lowers the value. Doing the towing adds value.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: November-02-2018 at 10:44pm
Cousin Donald,this is why my price is non negotiable. The Mrs is well aware of the historical significance of being towed by the very first National Tow Boat from back when they started the program in 1955. I believe the Hurricane has towed the waters of Cypress Gardens Florida all the way to Deep Lake Illinois.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: November-02-2018 at 11:55am
I concur, given the situation the M-600 is best value
And get a good spin-on filter housing, throw the fram cartridge away and don't look back
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: November-02-2018 at 11:52am
Zach,
Very valid points on rebuilding the old carb and the basic health of the engine. Maybe Brant can fill us in on exactly what problems he's having and what diagnostics he's done.
phatsat67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: November-02-2018 at 11:28am
I wouldn't put money into a rebuild of that carb with 2000 hours unless you are going to have the throttle shafts bushed. There will be quite a bit of wear on those shafts which translates into an unfixable vacuum leak and causes key start and idle issues.
I wouldn't even dream of a 300 dollar rebuild when I can grab up a superior carburetor for just shy of 200 more. Sort of like your 2300-9800 comparison on the efi conversion vs repower with modern engine. Why rebuild an old pile when for less than another rebuild more you can have the best new marine carb on the market. Do yourself a favor and pickup the quick fuel M-600.
Also, at 2000 hours I would also assess the health of your engine. Compression test to make sure you aren't seeing running issues from worn valves/low compression etc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: November-02-2018 at 11:27am
My carb is starting to have trouble
You haven't mentioned what the trouble is. Are you sure it's the carb? Have you done anything to isolate the problem(s) to tell you it's the carb?
Also, many here have rebuilt the 4160's themselves so give it a try.
skierbrant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skierbrant Quote  Post ReplyReply Direct Link To This Post Posted: November-02-2018 at 11:21am
Post Options Post Options   Thanks (0) Thanks(0)   Quote samudj01 Quote  Post ReplyReply Direct Link To This Post Posted: November-01-2018 at 11:28pm
I included that we have all been there. I expect to be there again. Just hope i have friends nearby.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Donald80SN Quote  Post ReplyReply Direct Link To This Post Posted: November-01-2018 at 1:53pm
Originally posted by samudj01 samudj01 wrote:
Ha, that joke may never get old. Poor Donald had to do the towing but we have all been there. And to Greg's credit, I stopped by the other morning and he was hard at work putting in a new fuel gauge and sender. Fool him once shame on the boat, fool him twice shame on Donald, but not again!
David,
I also remember towing a Yellow Ski Tique at White Lake, but it did have fuel in it. I do believe I have a rare National or Regional Tow Boat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCH20SKIER Quote  Post ReplyReply Direct Link To This Post Posted: November-01-2018 at 12:55pm
Pete,
I had a gauge and installed a year ago and never got to testing the the sending unit as I was to busy enjoying the boat. While I had the boat in the garage last weekend for other items I pulled the sending unit out to find that there was no possible way the float mechanism would operate as intended (no free movement of the float arm) and also by shorting out the sending unit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Riley Quote  Post ReplyReply Direct Link To This Post Posted: November-01-2018 at 12:54pm
When it comes to fuel consumption, I refer to our BFN as a BFP.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75 Tique Quote  Post ReplyReply Direct Link To This Post Posted: November-01-2018 at 12:49pm
Also to Greg's credit and to give him a pass on this one, he made the mistake of leaving his BFN with a bunch of us yahoos while he ran back to the house in his 206, which took longer than he expected, because, nice guy that he is, he stopped and towed someone else in. (not even one of our group) Meanwhile, us selfish yahoos took countless WFO barefoot runs behind his boat while he was gone and then gave it back to him for the trip in.
So he gets a pass on that one. Now earlier in the season, when he, Kristin and I were out for a few runs.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: November-01-2018 at 12:32pm
Greg,
Both were bad? That's very unusual. How did you diagnose both were out?
Post Options Post Options   Thanks (0) Thanks(0)   Quote samudj01 Quote  Post ReplyReply Direct Link To This Post Posted: November-01-2018 at 12:07pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75 Tique Quote  Post ReplyReply Direct Link To This Post Posted: November-01-2018 at 10:23am
Originally posted by NCH20SKIER NCH20SKIER wrote:
I recently installed a Quick Fuel on the 85 Barefoot Nautique. Very pleased with the results
They've got one fussy little quirk tho, apparently you have to run gas through them for them to work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCH20SKIER Quote  Post ReplyReply Direct Link To This Post Posted: November-01-2018 at 8:52am
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2018 at 8:49pm
Brant,
Have you made any decisions yet on the EFI? Which system you will be using? The $2400.00 one Eric linked?
KRoundy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRoundy Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2018 at 6:20pm
Cool! I want to see what you do and how this works. How are you going to install a fuel pump in your boat? We are all very curious to see how the oxygen sensor is installed and works. Post photos and take us along on your journey!
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2018 at 10:25am
I see the EFI kit includes a "specialized O2 sensor bung"
Several questions were asked about the o2 sensor installation, but were never answered.
Kinda sketchy IMO
Goldcup101 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Goldcup101 Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2018 at 6:48am
I recently installed a Quick Fuel M600 and the boat is transformed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2018 at 2:10am
The thing I don't understand why anyone would spend this kind of money for essentially a band aid type system. In the last couple of years I have personally come across 4 GT40 engines being parted out. You could relatively cheaply install a computer controlled factory system yet the guys selling sat with them piecemealing parts off til little was left.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2018 at 1:16am
With your standard output 351W, I don't believe that you will see significant improvement with a throttle-body EFI unit. For less than $500 you can install a QuickFuel marine carb that will out-perform the Holley 4160 that you now have -- without having to go to EFI. See link below.
LINK
My 1994 High Output 351W came with factory throttle-body EFI. However, when that system failed, I went to the QuickFuel carb. I spend quite a bit of time researching and asking the experts about the after-market throttle-body EFI kits and I decided to go "backward" to carbureted.   That was several years ago. Today, my engine starts easily and performs at or near the throttle-body EFI
Just my 2¢
Orlando76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: October-30-2018 at 11:42pm
I agree Pete. A properly tuned carburetor will run 99-100% on par with an efi setup. If it doesn’t, it’s the mechanics fault. I foresee a Holley 4160 being produced 20 years from now. I do not foresee all the electronics being produced for the Gt40 or Excal engines in 20 years and especially not for aftermarket efi setups. Only possible advantage I see with efi is if the elevation you run your boat changes drastically.
1976 Ski Nautique 351 Escort
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-30-2018 at 11:25pm
Originally posted by erbrown101 erbrown101 wrote:
Picked up one of these earlier this year.
https://www.summitracing.com/parts/fst-30365-06kit/overview/
Going in an '88 2001 SN. Haven't had time to install yet.
direct link
And some advertising from their marketing dept.:
"FAST EZ-EFI marine base kit fuel injection systems upgrade the rough idle and poor cold starting often associated with engines running a carburetor, while improving overall performance and drivability."
I never knew my carb'd engines were so bad!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-30-2018 at 11:20pm
direct link
erbrown101 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote erbrown101 Quote  Post ReplyReply Direct Link To This Post Posted: October-30-2018 at 10:39pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote skierbrant Quote  Post ReplyReply Direct Link To This Post Posted: October-30-2018 at 10:26pm
Will do!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-30-2018 at 4:05pm
Brant,
If you do go the EFI route, make sure you keep us informed through the install and then the results.
