  New Posts New Posts RSS Feed - Hull hugger leaking?
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Topic: Hull hugger leaking?
    Posted: November-03-2018 at 1:16pm
Better to caps both ends,
Put a small fitting in one of the caps so you can pressurize it (a couple psi) & put under water to look for bubbles.
You could also use soapy water but that is hard to pinpoint the exact leak.
Wtrskior View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wtrskior Quote  Post ReplyReply Direct Link To This Post Posted: November-03-2018 at 1:04pm
Entirely possible I suppose but I never noticed any water coming from that area. With how much water I wAs getting when underway I feel I should have noticed from that area.
I've thought about capping the muffler exits, filling with water to test it
2001 Ski Nautique CB w/ GT40
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: November-03-2018 at 11:51am
Kyle,
Could the exhaust hose connection been leaking?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wtrskior Quote  Post ReplyReply Direct Link To This Post Posted: November-03-2018 at 11:38am
I have had a leak onboard when underway only. Always warm water so has to be coming from exit side of cooling water.   Can't see it coming from the motor and looked to be a little stream from under the muffler. So I've pulled it now and can't see any obvious holes?    There are areas that have the black worn off but overall it looks to be in good shape.
Any ideas on how to better test the muffler for leaks?
