engine rotation |
turboapache ![]() Groupie ![]() Joined: February-19-2012 Location: Lake Placid Fl Status: Offline Points: 46 |
![]() ![]() ![]() ![]() ![]() Posted: January-22-2019 at 6:18pm |
Thanks to all. I guess I will keep the eng as is since everything is brand new inside. I will clock the trans correctly and get a left hand prop. Anyone have a spare left hand prop they would part with? This is for a fish nautique.
there is no substitution for cubic inches.
TRBenj ![]() Grand Poobah ![]() ![]() Joined: June-29-2005 Location: NWCT Status: Offline Points: 21198 |
Slipped a bunch. Take 2 next year (maybe).
Duane in Indy ![]() Platinum Member ![]() ![]() Joined: October-26-2015 Location: Indiana Status: Offline Points: 1578 |
Thanks TR. On a side note: did the new clutch pack ever get tested??
1978 Mustang (modified) |
Harmonic balancer isn’t functionally different but the timing marks would need to be reversed if using anything other than 0deg/tdc. Index the rwp also if you’re converting a bobtail lefty to righty. Otherwise Z has the bases covered.
Short answer to Duane’s question is no... long answer is yes/maybe/sort of but not inexpensively. Ie, you can make a LH engine turn a RH Prop with either a Pcm 1.23 or ZF63, but those are $2k+ gearboxes, plus you’ll need a new shaft and propeller to match. And you’ll need to confirm the longer body (versus the velvet 1:1) fits in the hull. |
KENO ![]() Grand Poobah ![]() Joined: June-06-2004 Location: United States Status: Offline Points: 11196 |
Turbo
I think I'm confused, Here's a link to your thread from a year ago, Seems like things are changing link |
Zach, Would it be possible to just change out transmissions and let it reverse the prop shaft rotation???
phatsat67 ![]() Grand Poobah ![]() Joined: March-13-2006 Location: Indiana Status: Offline Points: 6157 |
Depends what year of engine you are working with.
If it is a 2 piece rear main seal you will need a completely different crankshaft. You will need a proper distributor or a gear to swap onto your existing distributor. You will need a different starter. You will need a proper rear main seal if you are running a one piece rear main seal engine You will need a new camshaft/lifters. You will need to index the transmission pump the opposite direction if it is set up for std. rotation. I believe the reverse rotation engines take a specific vibration damper as well It's early I may have forgot something. I would suggest just looking for a running take out if you can find one unless you are building a fresh engine anyways. |
what parts are needed to change the rotation from standard to reverse rotation on a 351w?
