Making lake ice |
Post Reply | Page 12> |
skutsch
Grand Poobah Joined: June-19-2008 Location: Racine, WI Status: Offline Points: 2874 |
Posted: January-31-2019 at 3:06pm |
Square tires, I remember that... Haven't started my car that sits out since Sunday (was in Chicago all week), I think I am just going to wait until Sunday when its back in the 40's... That is what is so crazy about all this, we are going to have a 70 degree swing in temps over the next couple of days. CRAZY!
With the cold, frost quakes have been hitting the news. I took a walk down to the lake last night and I never remember hearing as much "ice quaking" as I did last night. I'm going to have to get the auger out and see just how much is out there. I have been hearing from the ice fishermen that there's 24" plus.
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21189 |
LAIR Editing people’s quotes, smh. |
So far good but, yesterday after work it was a very slow crank and then thankfully it fired. I did bring the jump box with me just in case. I've been thinking about a new battery since it still has the original 9year old one in it. At home it does sit outside but the block heater gets plugged in. Yes on driving square tires for a couple miles! |
Hollywood
Moderator Group Joined: February-04-2004 Location: Twin Lakes, WI Status: Offline Points: 13517 |
cool edit sir
that's why I quote, because of liars like u |
Try f12 again, derp. Might take 2 tries with the cold temps.
Hollywood
Hollywood
How does the lesbomobile handle the bitter cold?
I hand to manually pull the ignition switch back to run from start and then felt like I was driving on square tires at -25 this morning. |
75 Tique
Grand Poobah Joined: August-12-2004 Location: Seven Lakes, NC Status: Offline Points: 6130 |
I've been thinking about you Pete and wondering how you are surviving that crazy cold weather up there. Sounds brutal.
Not diluted, 50-50 and 75-25 are out in the cold. We'll see what happens. I did not use glass but rather 3 4" sections of copper pipe. I thought of the copper the last couple days working in the plumbing dept. at the HD. I had plenty of customers come in needing supplies to fix their busted water lines! We are also out of stock on heat tapes!! |
Faceplant
Senior Member Joined: July-27-2013 Location: Otter Lake , Mi Status: Offline Points: 418 |
Mail halted today and tomorrow here in Michigan. Had a little hop to my skip while walking in the woods today enjoying the scenery.
SNobsessed
Mail delivery halted today, as well as all city buildings closed.
Cabin fever coming on already! |
fanofccfan
Platinum Member Joined: December-13-2009 Location: North Bend NE Status: Offline Points: 1791 |
We are not nearly as cold here, -16 supposed to reach a high of at least 4! outside chance of getting all the way up to 6! Global warming will be here this weekend as the forecasters are calling for 45-50. I am patiently waiting for the results of Pete's experiment.
SNobsessed
-25F here in Iowa @ 7AM
My house was creaking last night from contraction & (I assume) nails pulling loose. Furnace did not run 100% so I have extra capacity left. The high today is supposed to be -18F. Will be a good test for the car battery! |
Riley
Grand Poobah Joined: January-19-2004 Location: Portland, ME Status: Offline Points: 7954 |
No, some of us just worry about cheaping out on the -50 anti freeze and not splurging on the -100 stuff. |
Morfoot
I don't how y'all do it.... That's just too friggin cold for this Georgia Boy. When it's that cold out do y'all still put a lamp under the engine cover to "warm" it up a bit to keep the antifreeze from freezing? I acquired a marine engine compartment heater that I put under Miss Scarletts bra as temps in the 19F might chill down the garage to below freezing and yes she still has lake water in her veins...
Stay warm you guys.... |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11141 |
Put it in a small glass container that won't bulge.and fill it all the way
And mix it in the ratios like mentioned above It looks like it's 49 degrees indoors on your thermometer, better throw a few more logs on the fire |
Mpost
Senior Member Joined: July-05-2018 Location: Monticello, MN Status: Offline Points: 330 |
Checked the 2 gallons of -50 AF in the garage. Slushy but not bulging the bottle yet. Only -15 in the garage so I set one outside to see what -30 does to it. Keep warm Pete. |
84 SN Sold 98 SN Lund Pro V 1975 Alumacraft
MrMcD
Grand Poobah Joined: January-28-2014 Location: Folsom, CA Status: Offline Points: 3754 |
Dang Pete, that is wicked cold, my son has a home in North Pole Alaska and it is warmer than you are seeing! I saw the temp dip just a bit below 50 here and I am cold. You guys must be frozen. Stay warm, you know we are in global warming so your record temps are not real. Just pretend you are warm!
Hope you stay safe, the body is not meant to survive at those temps. |
I can't win - When I wear my Thomas Magnum short shorts everyone yells too
Are we going to have to go through this again? |
It's all relative - I had to wear long pants to go to lunch in the boat today.......
Ken,
I'm out of anti so I'll pick up some at work tomorrow. Tomorrow night would be a better test anyway since they are predicting the temp tonight to only drop to -28. Tomorrow the prediction is -31. |
Pete
With your forecast for the next few days, you need to do something useful like mix up some of that pink minus 50 antifreeze in a couple of different batches like a 50% water to 50% antifreeze mix and another one with a 25% water to 75% antifreeze mix. Fill a couple of glass jars stick them outdoors and see if the jars are still in one piece in the morning. No need to sit outdoors watching them all night Gary might think differently though |
gt40KS
Gold Member Joined: August-05-2017 Location: Wichita Kansas Status: Offline Points: 946 |
Too frigid for this Kansas boy - I don't care for the 15 to 35 that we have here !
I'd be much happier with Arizona weather all year |
JCCI
1995 Ski Nautique GT40 |
Mpost
We managed to put 100 miles on yesterday Pete. Was a balmy -4 when we got back to the cabin. |
89 degree difference between us and were on the cool side.....
Now we're making some real good lake ice. I'm at -27 with no wind chill.
