Engine Rebuild |
Post Reply | Page 123> |
Author | ||
jterr
Gold Member Joined: February-13-2018 Location: N. Florida Status: Offline Points: 621 |
Posted: May-11-2020 at 10:20pm |
It's checked now but will log out and see if that works. Thanks |
Look down at the bottom of the message box. There's a box to check for email replies. If you logged out and then back in, I believe you need to check the box again |
jterr
Just a quick question . Any idea why I'm not getting e-mail notifications???
jterr
After looking closer the arm has gotten bent and actually shorted on the screw. Kinda straightened and it runs again???
Still the Tack pegs and stays there even with engine running ; think I will buy another and try. |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11118 |
JT That's some kind of magic distributor you got yourself there In the first picture the points would never close so it's seems kinda hard (like impossible) to make a spark and make the engine run. In the second picture, it looks like they're still open and they'll never close unless it's camera angle or lighting or something making it look that way, making it equally impossible to get a spark. |
jterr
It never ends
Decided to make sure engine runs after all the wiring issues. Engine was running ok and I never went into the Distributor Check this out?? You could almost drive a truck through the gap This as close as I could get |
jterr
Little stiff, but with 2 bad shoulders and knee I'll deal with it. I still have to finish carpet under there yet Thanks Was hoping to go to Lake Sunday for the water test but 80 % chance of rain |
John,
How's you back from crawling under the dash? I know it gets tougher and tougher as time goes by. |
jterr
Well I took all gauges out and cleaned/reconnected and wired by the Diagram above. I did find the 3 connectors on back of Tach and moved around and back to 8 cyl.
After all the above Tach still pegs so maybe it is bad. Will see what it does after I get engine running again when don with Carb. Thanks for all the info |
Good. So now you know the gray wire isn't connected to anything else. |
Thanks(1)
JT
With the gray wire hooked up to the coil(-) your reading of 11 or so volts is normal with the key in the Run position depending on the points position. Assuming you have points, if the points are open when you turn the key to Run, you'll have the same voltage as what's going into the (+) terminal of the coil from the ignition switch. If the points are closed when you turn the key to Run, you'll have no voltage because the coil is going to ground through the points. If you pop the cap off and see if the points are open or closed, you'll know what you should be seeing for voltage based on the above. The tach needs 12 volts from the key, a ground connection and then the pulse signal to give indication comes from the gray wirehooked to the coil (-). The pulse itself is that change from 12 or so down to zero volts every time the points operate. With it pegging when the key is turned to Run, you should probably look on the back for a small switch for selecting the input. It might be inside a little hole or you might be able to see it pretty easily. Most tachs have this selector. With a little "tweaker" you can move that switch from it's present position to the next position in either direction and cycle it back to where it was a couple of times. This will clean the contacts if they're dirty or have a little corrosion. Different tachs are labeled differently but you should find the switch in the 8 cyl position and end up with it back there too.. Then with all the wires hooked up normally, it may work again. It won't hurt to try this. I have a tach that does just what yours does and needs this every few years or so And then again, maybe it's just dead If it's an electronic ignition in the distributor, all the same info pertains Just an oh by the way....................your dash diagram shows an ammeter setup and your photos in other threads for this boat show a voltmeter next to the ignition switch so that explains your missing red wire you mentioned. |
jterr
Wire from Tach no volts.
Also read that a dead light bulb could be a cause; but after disconnecting it as it is burned out same pegging. |
Thanks(1)
John, Thinking again about getting the voltage reading from the gray sender wire at the tach, I should have told you to also disconnect the positive wire on the coil. Try it again and see what you get. The idea here is to make sure the gray wire isn't connected someplace else since you mentioned you other connections in the wire harness/loom. |
jterr
John, did you get the VOM out and check that gray wire. Also, disconnect the gray wire at the tach an check it for voltage when you turn the key on. Report back what you get QUOTE] Pete just curious about this reading? Alrighty then-here are the results Disconnected wire from Tach got a reading of 11.01 volts with key in on position. |
John, Considering the wiring problems, I wouldn't be surprised. The one way to find out is to go after the wiring tomorrow. |
jterr
I did figure these wires out they were for the bilge pump and blower |
jterr
Just a note I don't think those lights in the gauges work as I have not seen anything light up. My new switches are the things I was talking about the were lighting up.
Tomorrow is another day |
Thanks(1)
John, Do you still have the instructions that came with the meter? If so, get them out and do some reading. On many VOM's, that sound setting is for checking diodes. Check that. The purple ignition wire also has a path to ground. Via the coil and the electric choke so, you will get the audible there too. As mentioned, get those instructions out and do some reading while you're regrouping. . |
jterr
I was using the meter sound to check
Don’t know how to check residence. Also the purple ignition wire is doing the same with the ground. I’m gonna stop for the day as I really not close to understanding bout brain dead Have to regroup tomorrow |
Since all the grounds are daisy chained, I suspect when you took the wires off, you broke the chain. |
John, What are you using to check continuity between the light blue and black? If not resistance with a VOM, then you are getting continuity through the instrument light bulbs. That red wire is the main positive feed to the dash. |
jterr
[QUOTE=8122pbrainard] John,
The "G" terminal on the tach should be ground. **Check. There is 1 black wire and 2(connected together) black wires on the same G post. I took the 2 off and they don't have continuity to the other ground wires The light blue and black wires should not be connected. The light blue is the positive feed for the instrument lighting and the black is the ground for the same. **Check. They aren't connected anywhere I can find, but when I check the continuity they are together somehow. I guess I will take off all the blue light wires I see if I can see a difference./QUOTE] How about that red wire?? |
John,
The "G" terminal on the tach should be ground. The light blue and black wires should not be connected. The light blue is the positive feed for the instrument lighting and the black is the ground for the same. |
jterr
More cornfused now. See green notes on wiring diagram
Also while checking ground when I touched the blue light wires on gauges to black ground wire they show connected |
jterr
Disconnected wire from Tach got a reading of 11.01 volts with key in on position. Tach is still pegging even with that wire disconnected so I must have something wrong somewhere Back to the boat |
jterr
I checked for continuity. Electrical really keeps me confused |
John, did you get the VOM out and check that gray wire. Also, disconnect the gray wire at the tach an check it for voltage when you turn the key on. Report back what you get BTW, voltage ratings on fuses are the MAX rated volts. |
jterr
Bad fuse at the key switch, replaced with a 32v ( all I had) lights work.
Back to Tach- still pegs to right. Thought I would just take off wires at coil, still pegs when turn key on What to check now? |
jterr
Well after a couple hours rechecking and redoing connections most everything is working-except the lighted switches
They have been working all the time till today??? oh well back to rechecking |
jterr
Found several bad connections in harness. Fix tomorrow
