Pics of Bildge Pump Install 65 Cuda |
Riley ![]() Grand Poobah ![]() ![]() Joined: January-19-2004 Location: Portland, ME Status: Offline Points: 7963 |
![]() ![]() ![]() ![]() ![]() Posted: March-01-2019 at 2:50pm |
Nice job. I haven't seen that type of pump before. Does it have a built in float? It must have a pretty low profile? I had originally installed the bilge pump in our Cuda just behind the bulkhead, but it could only be accessed through the console, ( a real PIA). I since moved it back, but could not put it where you have it as the pump is too tall.
Orlando76 ![]() Grand Poobah ![]() ![]() Joined: May-21-2013 Location: Mount Dora, FL Status: Offline Points: 3108 |
I like it!
Scott,
Nice idea. I like it. 800 gph! Wow, you must have a problem. Gortex makes some really good packing. Maybe you should check into it for your rudder and shaft packing glands? |
phatsat67 ![]() Grand Poobah ![]() Joined: March-13-2006 Location: Indiana Status: Offline Points: 6157 |
Nice looking setup. Probably gets it down a little further in the bilge vs. a flat area to screw into.
Fiberglassic ![]() Groupie ![]() ![]() Joined: October-09-2017 Location: Raleigh, NC Status: Offline Points: 62 |
I’ve always been a believer that being able to easily service your bilge pump out at sea is as important as having one altogether. My 1965 Barracuda pump needed to be replaced. After spending 2 hours getting it free from the bilge, I decided to make a new mounting system that will enable me to un-mount it in less than 2 minutes. I created a pictorial that I hope you can understand how I did it. Enjoy…Scott
Scott
