  New Posts New Posts RSS Feed - Prop spinning in neutral
desertskier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertskier Quote  Post ReplyReply Direct Link To This Post Topic: Prop spinning in neutral
    Posted: April-03-2019 at 4:32pm
Good idea. I will add it to the list.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-03-2019 at 2:29pm
Originally posted by JoeinNY JoeinNY wrote:
While the typical dirty neutral is in due to internal issues, either minor or less so – this presumes that you have your control cables correctly adjusted.
Originally posted by desertskier desertskier wrote:
My '89 has an intermittent dirty neutral also. If I feel it turning I can give the throttle a little blip and it usually stops. .
Sean,
That "blip" may be repositioning the trans shift lever. Do check your cable adjustments.
JoeinNY View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: April-03-2019 at 12:50pm
While the typical dirty neutral is in due to internal issues, either minor or less so – this presumes that you have your control cables correctly adjusted. Its worth removing the cable to see if you can find a position with the transmission control level that stops the spinning. If you can time to adjust the cable end.
1983 Ski Nautique 2001
1967 Mustang 302 "Decoy"
Holeshot Video
Post Options Post Options   Thanks (1) Thanks(1)   Quote desertskier Quote  Post ReplyReply Direct Link To This Post Posted: April-03-2019 at 12:28pm
My '89 has an intermittent dirty neutral also. If I feel it turning I can give the throttle a little blip and it usually stops. It was worse when I first bought it but it also needed a dampener plate. After replacing the plate it seemed to get better but hard to tell since I hadn't run it very much.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-03-2019 at 11:16am
There's something inherently wrong with having fingers and a moving prop or prop shaft in the same location
You haven't had the pleasure of meeting Kristof!
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: April-03-2019 at 11:11am
Originally posted by Kristof Kristof wrote:
It's not really normal, but if you can easily stop the shaft with your 2 X4, I'd leave it alone, put it in the water and see how it acts, then decide if you need to do something about it.
When on the trailer, I can stop the prop with two fingers...
When in the water, I can stop the shaft with three fingers...
Mine has done so since I have the boat and also did so with the previous owner. and this without any issues.
I even use the dirty neutral when I want to load her on the trailer at the ramp very, very, very, very, very slowly
Kristof View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kristof Quote  Post ReplyReply Direct Link To This Post Posted: April-03-2019 at 10:32am
- Money doesn't make one happy, but when it rains cats and dogs, it's still better to cry in a Porsche than on a bicycle...
Post Options Post Options   Thanks (1) Thanks(1)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: April-03-2019 at 9:04am
Like Kristof said, it's referred to as a "dirty neutral"
It's not really normal, but if you can easily stop the shaft with your 2 X4, I'd leave it alone, put it in the water and see how it acts, then decide if you need to do something about it..
Plenty of boats running around out there with a dirty neutral for years and years without any issues.
In the link below are a bunch of threads about that "dirty neutral"
Keep in mind that on an 89 you have the PCM 1.23 to 1 transmission when reading about this
PS hope you're wetting the strut and cutlass bearing when you're bumping it into gear on the trailer or you'll be putting undue wear on the cutlass bearing. Loud groaning noises will be your first indication of the shaft spinning in a dry bearing for very long.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Kristof Quote  Post ReplyReply Direct Link To This Post Posted: April-03-2019 at 4:03am
So does mine. Has always done it. Never bothered to do anything about it.
It's called a "dirty neutral"...
bfootr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bfootr Quote  Post ReplyReply Direct Link To This Post Posted: April-02-2019 at 9:42pm
Restoring a 89' SN that I purchased last Nov. It needed a lot of work. Engine was seized and after much work and numerous parts, we got the engine running. We haven't had the boat in the water yet. I noticed that while running the engine on the trailer (w/ water hookup), the prop will spin slowly (maybe 60 -80 RPM's per minute) in neutral. I am able to stop the spinning somewhat easily by applying some pressure on the trans coupler (w/ a 2x4). Trans seems to operate smoothly in and out of gear. The spinning will stop as I increase throttle in neutral. Is the spinning in neutral at idle normal? I would think maybe the spinning will slow once in the water with prop load applied. Appreciate any advice. Thanks!
