  New Posts New Posts RSS Feed - Prop selection question
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Topic: Prop selection question
    Posted: August-17-2019 at 12:02pm
A few pictures of Mav's boat
The tall pylon
An aluminum intake with brass water passages. I think that's original on the high output engine and expensive
There's something not quite right about the dashboard
Also took a picture of the PCM tag on the engine, but didn't come out real good
It's a PLN WR L10 or by PCM literature it's a 390 HP Left Hand Rotation 454 with a 1 to 1 Borg Warner transmission. and an 8.6 to 1 compression ratio.
phatsat67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: August-16-2019 at 6:14pm
My 86 trailer had ample propeller clearance. My 85 trailer did not. I ended up putting the back of a forklift over the middle of the prop guard and lifting the edges of the guard with a crane. Bent back into place nicely and squared up the rear parts of the trailer main beams.
That said, this boat had a 3500 lb axle (Smaller tires) and the axle was mounted on the top side of the springs. This explains why the prop guard was bent up so much. I ran a 5-6" drop and it would still hit the ground a lot over small road changes etc.
Take a look at how the axle is configured and I bet the prop guard is pretty bent up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: August-16-2019 at 6:05pm
Well, after a trip to Mav's this morning, he got the puller and was waiting on the prop to show up later in the day.
The old prop was beat up but not terribly bad, we (or I should say he got the prop off while I helped) without much problem.
Part of my "help" was checking out the rest of the boat, engine, drivetrain etc and letting him know what I found.
Other than finding a big ol' 454 in there, he had replaced the original HEI automotive distributor with a Delco EST( that's for electronic spark timing) Marine distributor.
No flyweights and no springs, the advance curve is programmed into the module.
It was a good looking install
Next I was looking at the transmission coupler and shaft couper and got to break the news to him that he has an ARE shaft in the boat
Moved on to checking the runout on the shaft and it was straight and spun easily by hand even with a dry cutlass bearing. No excess play in the bearing either
Took some pictures that will get posted later
The boat itself, like mentioned in his other thread is an 84 that's had the Rustoleum stripes stripped off and the maroon on the sides is done in something that's as hard as nails and then OEM vinyl lettering put in place.
The interior is kinda rough but that can be taken care of
The pylon is a tall factory one that sticks up above the windshield slightly.
He has the same rudder rash as Flyweed just posted about only not quite as bad. Since it's a Lefty, the rash is on the right side of the rudder
We talked about installing the prop and I m mentioned a few other things also and had to disappear because of other stuff I had going on.
I figured he could handle the prop install and a trial run tomorrow.
Not quite though, he called a few hours later to say that the Acme 431 wouldn't go on the shaft and be able to rotate 360 degrees without hitting the prop guard. The old prop had probably an inch of clearance and I had a 13 by 14 oldie that I brought that also had the same inch or so clearance.
Not the Acme though   Funny thing about the rake on the prop
So he's now into a little reengineering of the prop guard and measuring prop and rudder clearance from the pavement, gravel, grass etc in case he unbolts the guard.
He did say that he doesn't have much clearance from the guard to the ground on a level surface. I think he already has the trailer a little nose down from level when towing to gain a little clearance.
Maybe somebody can post a picture of a mid 80's SN with an Acme on the stock CC trailer for comparison
And the shaft isn't too long since there's probably 5/8 -3/4 inch clearance from the strut with the old prop and I didn't see it with the new prop but I imagine it's about the same.
Sometimes even a straightforward prop change isn't so easy
Once he's past this speed bump, then he'll be able to see if the prop cures his issues or if maybe it's a transmission or coupler issue
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: August-13-2019 at 8:37pm
My 430 runs 1:1 above 50 (50.5 at 5050rpm with a 330hp 454) and that’s on a slightly more efficient/faster hull. If this is a legit 54mph boat, then with the less efficient 2001 hull, I would expect closer to 5500rpm to get there (with a 430/431). A 1598 equivalent (1459 minus cup) would dial the rpm back by 300rpm closer to the 5200rpm goal. Now if the boat isn’t quite that fast maybe the 431 will get it closest to the power band. Kind of a crap shoot without a good set of baseline data.
Crmaverick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Crmaverick Quote  Post ReplyReply Direct Link To This Post Posted: August-13-2019 at 5:19pm
Originally posted by JoeinNY JoeinNY wrote:
1459 minus some cup would be ideal. 1598 in lefty form (same prop but .080). The 431 would run closer to 1:1 at 5100rpm, the boat should be capable of 55 if the motor is healthy.
Based on what boat?   Am I forgetting a 2001 hull boat that has shown a legit 54 mph on a gps? A 431 for the win - 5250 at 53-54 gps mph on a good day would be my bet. My dynoed 403 hp - lighter engined LH version wasn't asking for more prop than a 431. I was down 10 percent cubic inches so likely down a bit of torque lower in the cure and therefore might have enjoyed a bit more prop but I doubt it would be worth lugging the motor all the time. I think the general rule of unless you increased displacement you should keep the same prop but expect to spin it faster applies.
- My 431 met a very large rock at a very slow speed - one blade folded over badly - operator error for sure.   Although I am going to blame the equipment operator that built the brand new pier with ladders and cleats and a pile of boulders all along the side 12 inches under the water.
Ordered a 431 today and the other one was shipped back. I should have the 431 on Friday
JoeinNY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: August-13-2019 at 11:39am
1983 Ski Nautique 2001
1967 Mustang 302 "Decoy"
Holeshot Video
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: August-13-2019 at 11:04am
Mav, three decades ago with a similar boat (sister boat to yours) a wise man limited our boat speed with tubes to 22 mph, else it gets put away.
Believe me, you can still cause both fun and carnage with those limitations and i still use that rule of thumb towing our guests (when the lake is clapped out on a weekend, of course)
Your boat is capable of absolutely wrecking someone, so just wanted to pass on don't let your guard down
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75 Tique Quote  Post ReplyReply Direct Link To This Post Posted: August-13-2019 at 10:55am
Dave
I'm out of lapping compound, So I think I'll mix up some sandblasting grit with some toothpaste and give it a whirl
I'm just not sure if I should use extra whitening or fluoride or maybe some herbal more natural type stuff.
Crest, Colgate, Aim, and so many others to choose from
Decisions, decisions
A new shirt is on the agenda too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Crmaverick Quote  Post ReplyReply Direct Link To This Post Posted: August-13-2019 at 10:48am
Originally posted by GottaSki GottaSki wrote:
Mav, while we sort this out, whats the list number on the carb's air horn?
should be -9022. Let us know is you find something different.
That’s it 9022, it codes out to an 800 cfm
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: August-13-2019 at 10:46am
should be -9022. Let us know if you find something different.
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: August-13-2019 at 8:33am
Originally posted by 63 Skier 63 Skier wrote:
check the shaft taper, see if it's straight and depending on our mood maybe even do some lapping
If so, make sure you wear your white monogrammed dress shirt.
Chris, you are getting some first rate help!
Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: August-13-2019 at 8:17am
Since Acme doesn't seem to make what he's describing which would be a 13 by 14 prop with .080 cup to fit a 1 inch shaft,you have the 2 choices mentioned earlier.
The 1459 or 431.
Don't even think about the 1595, get it out of your mind
I'd figure if you not feeling adventurous you go for the 431 being a more equal replacement.
Nobody really knows your engines health but if you're feeling a little frisky, then the 1459 will hold the rpm's down some and maybe give a little more speed.
Then again, you mentioned earlier that the 13 by 14 props weren't available for some reason so the choice could be made for you already.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Crmaverick Quote  Post ReplyReply Direct Link To This Post Posted: August-13-2019 at 1:08am
Thanks for all the help everyone. Would this be the ideal prop you’re describing except 1”?
http://www.nettleprops.com/store/p/440-Acme-1595-Propeller-3-Blade-13-x-14-LH-1-1/8-Bore-080-Cup.aspx
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: August-13-2019 at 12:53am
Post Options Post Options   Thanks (0) Thanks(0)   Quote 63 Skier Quote  Post ReplyReply Direct Link To This Post Posted: August-13-2019 at 12:33am
baitkiller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote baitkiller Quote  Post ReplyReply Direct Link To This Post Posted: August-12-2019 at 11:47pm
You are good man Ken. I have some lefties but all are 13 square and not enough to even try with all that ass under the hood.
Thanks for helping him out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: August-12-2019 at 11:21pm
Well, here's an update on Mav's prop story as of tonight.
To start with some background info, the boat's a mid 80's 2001 hull with a LH rotating , 400ish HP 454 that he recently bought and has been working on.
His issue is that the boat accelerates well, but if he punches it a 30 mph or so, it's slipping or cavitating or whatever.
He could use a new prop and what he has on it right now is a 13 by 14 LH prop that's somewhat beat up. That's the stamping on the hub anyways
And the key is in the keyway
He verified that the shaft is 1 inch diameter, he mistakenly thought it was 1 1/8 inches and ordered an Acme 425 that'll be getting returned.
His dilemma is ...........what to get
He could get an Acme 431 13 by 13 .080 cup
Or he could get an Acme 1459 13 by 14 .135 cup
I figure either is gonna work, the 431 will act a lot like the original 13 by 14 and was Joe's recommendation based on some of his previous destructive testing
Tim says a 13 by 13 Acme is not enough prop, which would lead to the 1459 choice
So...................which one?
He's gonna use it to pull skiers, cruise around and (don't read this part Pete), pull tubes
I'm gonna be in his area at the end of the week and we'll get the old prop and goofy collar off, check the shaft taper, see if it's straight and depending on our mood maybe even do some lapping
Then the new one can go on and see if his issue is resolved or maybe there's a transmission or coupling issue to deal with
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-12-2019 at 7:36pm
We are talking about 400 hp at 5100 ish rpm LH engine in a 2001 - acme 431 is the correct prop. Unfortunately mine didn't survive more than a day or two before I destroyed it, but worked great while it was on.
Joe,
What happened to the prop? Did it flatten out? Throw blades?
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: August-12-2019 at 6:47pm
Holeshot Video
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-12-2019 at 5:40pm
Originally posted by Crmaverick Crmaverick wrote:
What’s lap the prop to the shaft, is that putting in the key way?
Proper prop installation
Acme actually recommends the procedure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Crmaverick Quote  Post ReplyReply Direct Link To This Post Posted: August-12-2019 at 5:40pm
They're not used on many direct drive Barefoot 454's at all since forward would be reverse and vice versa.
And .....................the direct drive Barefoot 454's had a one inch shaft.
Hope you got it right
Hmm well the 425 I got is a LH 1 1/8 shaft.
Would a 13x12 prop have more top end speed than a 13x13?
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: August-12-2019 at 5:29pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Crmaverick Quote  Post ReplyReply Direct Link To This Post Posted: August-12-2019 at 5:24pm
Haha I hear they’re good props. I’ll be pulling skis and tubing, probably mostly cruising though
I see
Well a great prop but wrong size will still leave you flat, or worse, broken, you understand.
Something is amiss, continue to be patient with our inquiries, and we'll get you sorted out and undo what has been mismanaged prior to it getting to you.
A run of the mill 13x14 federal should still pull 3 footers on that boat so its not like you should need to experiment with an unproven recipe to get similarly good, solid
performance.
I actually ordered a acme 425 this morning
https://www.skidim.com/products.asp?dept=1130
Skidim recommends them on the barefoot 454, ordered from nettleprop.com for $345
Let's hope somebody replaced that original 1 inch shaft with a 1 1/8 shaft somewhere along the way
Otherwise it'll be a loose sloppy non fit
Hopefully a prop puller is in the order too, no fair beating on the old one with a hammer.
Good talking to you earlier today
I guess you won't need my loaner prop to try
Thanks yeah I saw that they were used on the barefoot 454 so I figured safe to order. I did order the puller and hardware kit
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: August-12-2019 at 5:19pm
I see
performance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Crmaverick Quote  Post ReplyReply Direct Link To This Post Posted: August-12-2019 at 5:15pm
That’ll come out of the hole well but you’re gonna need more prop up top... probably not the best all around choice. At least for an early hull with the HO.
Delta is a site sponsor and $10 cheaper with free shipping FYI.
Maybe I’ll send this one back if I don’t like it, what do you recommend for a delta prop on a 454 2001?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Crmaverick Quote  Post ReplyReply Direct Link To This Post Posted: August-12-2019 at 5:13pm
My next issue is how do I pull that old prop with that collar in the way?
You may need to disconnect the shaft coupling at the trans so you have room for the puller but, pull the collar along with the prop.
I recommend looking at the shaft very carefully and see why the collar is even on there.
Don't forget to lap the new prop to the shaft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-12-2019 at 5:10pm
You may need to disconnect the shaft coupling at the trans and pull the shaft aft so you have room for the puller between the collar and strut. Then pull the collar along with the prop.
I recommend looking at the shaft very carefully and see why the collar is even on there. I suspect there's damage to the tapered bore of the prop.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: August-12-2019 at 5:08pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Crmaverick Quote  Post ReplyReply Direct Link To This Post Posted: August-12-2019 at 5:03pm
I see
A run of the mill 13x14 federal should still pull 3 footers on that boat so its not like you should need to experiment with an unproven recipe to get similarly good, solid performance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Crmaverick Quote  Post ReplyReply Direct Link To This Post Posted: August-12-2019 at 4:59pm
I see
performance.
