  New Posts New Posts RSS Feed - Sudden cut-out
Sudden cut-out
smac76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smac76 Quote  Post ReplyReply Direct Link To This Post Topic: Sudden cut-out
    Posted: August-13-2019 at 11:05pm
I didn't place much faith in the NSS theory, but it doesn't hurt to ask. I'm still thinking its a carb thing. Right now I've been trying to run some fresh gas and Seafoam thru it to see if that has an effect. I'm reasonably sure the accelerator pump is working fine as the boat starts right up when I pump the throttle a couple times. Its had a tune up only about 4 engine hours ago, but that was 3 years back. It really runs well where I have it winterized, stored, and commissioned in the spring. I'm not sure they'd notice anything. if the boat wasn't under way.
It's 5 o'clock somewhere...
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: August-13-2019 at 12:06am
When you push the throttle do you get a good shot of gas out of the accelerator pump nozzles?
You can check this with the engine Off.
Disconnect the throttle cable at the carburetor and you can move the throttle linkage and look down the primary bores (with the choke open) and you should see a good shot of gas into each primary venturi.
If it starts right up (assuming you give it a couple of pumps of the throttle to start it) the accelerator pump is probably working, but you want to verify that the squirt of gas starts as soon as the linkage is moved
Like Pete said the NSS won't come into play with the engine already running
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-12-2019 at 10:47pm
Originally posted by smac76 smac76 wrote:
I'm thinking that the sudden shut off may be related to the neutral safety switch. Is this plausible? Has anyone seen where the safety switch at the throttle handle would cut out the ignition under normal operation?
First understand the NSS is not at the helm. It's on the transmission. Second, it only prevents cranking (turning the engine over with the starter) and has nothing to do with the engines ignition system.
When was the last time the engine had a tune up?
Post Options Post Options   Thanks (0) Thanks(0)   Quote smac76 Quote  Post ReplyReply Direct Link To This Post Posted: August-12-2019 at 10:38pm
So I've been working through some issues with my '76 SN, most attributed to just old gas and some carb tweeking. But the last nagging issue I'm having is that about 1/2 the time when I put it into gear and push the throttle down, the boat just shuts off. I used to think that was related to the other probs I was having, but now I have the boat starting right up, idling well, and running well for a blast across the lake- when I can get it off the dock.
I'm thinking that the sudden shut off may be related to the neutral safety switch. Is this plausible? Has anyone seen where the safety switch at the throttle handle would cut out the ignition under normal operation? I've noticed that once in a while the ignition is completely dead- no clicking, slow turning, etc- but after a little fussing around in the drivers seat, she'll turn over and start right up. Thinking that these may be related.
