  New Posts New Posts RSS Feed - Suggestion on Distributor Replacement for a 351w
Post Options Post Options   Thanks (0) Thanks(0)   Quote 67 ski nat Quote  Post ReplyReply Direct Link To This Post Topic: Suggestion on Distributor Replacement for a 351w
    Posted: August-18-2019 at 11:20am
Look into having your original points type completely restored, should work like brand new in 1967    This is my plan with prestolite
However it is always good to research what your electronic options are for backup.
I’m realizing some boats are better candidates for ALL original, classic , collector, show etc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: August-18-2019 at 1:43am
Not many choices, check the thread in the link
It's an unbiased list of what's available unlike JQ's totally biased opinion based on replacing his old clapped out ignition system with some brand new 70's technology
Guilty as charged. A totally biased opinion. Retro-Fit back to the 70's baby! Free bell-bottom pants with every DUI purchase...
JQ (stuck in old-school technology)
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-17-2019 at 9:50pm
Originally posted by oldskiboat oldskiboat wrote:
what is happening is that at 2500 rpm or if I push the throttle out of the hole the engine will bog down. If is start slow it will go fine till 2500 rpm and then opening up more will cause it to bog down.   I have a new carb on there and am putting the old one back to see if there is a change.
Gary,
What do you mean regarding "tacking"? You "think" the advance isn't working correctly. What's the timing light telling you?
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: August-17-2019 at 8:59pm
It sounds like it's not getting enough fuel maybe
Have you looked at things like the fuel pump, the anti siphon valve on the tank, the suction line in the tank or any filters in the system.
If you hook a temporary tank to the fuel pump inlet and see how it runs, it'll tell you some information
If it runs good then your problem is upstream of the pump
If it still acts up, it's the pump or carburetor or maybe the ignition system.
A small gas can with a line to the pump is all you need for this troubleshooting. Make sure the can is vented so the pump can draw fuel from it.
Why did you change carburetors?
oldskiboat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldskiboat Quote  Post ReplyReply Direct Link To This Post Posted: August-17-2019 at 7:45pm
Gary
The Villages Fl.
75Southwind 20
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-17-2019 at 7:38pm
Originally posted by Orlando76 Orlando76 wrote:
1/3 of the crowd will ask why change distributor and go away from points? I’m partly in this category. .
I'm in this 1/3 category. Rebuild the existing.
Thanks for the info.   I was having problems with the points, changed a set and condenser , and was getting tacking. Also changed the coil. Still having issues. Also think the centrifugal advance is not working correctly.   In other words the current distributor is a bit old and why not go with electronic instead of a new point type.
Gary,
BTW, I'm a "bit old" too but I still work!
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: August-17-2019 at 6:51pm
Edit here's the link below
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: August-17-2019 at 4:45pm
I'm in the D.U.I. crowd.
LINK to the best distributor you can buy
Cap color is RED. Reverse Rotation. No external coil needed. Just hook up 12V feed and tach wire. Good-to-go.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldskiboat Quote  Post ReplyReply Direct Link To This Post Posted: August-17-2019 at 4:41pm
Thanks for the info.   I was having problems with the points, changed a set and condenser , and was getting tacking. Also changed the coil. Still having issues. Also think the centrifugal advance is not working correctly.   In other words the current distributor is a bit old and why not go with electronic instead of a new point type. Comment are welcome.
Gary
The Villages Fl.
75Southwind 20
Orlando76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: August-17-2019 at 4:11pm
1/3 of crowd will say DUI Distributor. It’s and easy hookup, I have one. Big honking cap.
1/3 of crowd will hate DUI and say anything else but DUI.
1976 Ski Nautique 351 Escort
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldskiboat Quote  Post ReplyReply Direct Link To This Post Posted: August-17-2019 at 4:06pm
Hello all, I have a 1975 Correct Craft Southwind 20. It has a 1989 Ford 351w reverse rotation marine crate engine. It also has points. I would like to replace the complete distributor with a pointless unit. I am not interested in converting the existing point type distributor.   For those of you that have done this can you give me suggestions on what manufacture and model distributors would be good choices?
Gary
The Villages Fl.
75Southwind 20
