How did Correct Craft install foam on 78 SN |
Author | ||
uk1979 ![]() Platinum Member ![]() Joined: June-13-2007 Location: United Kingdom Status: Offline Points: 1426 |
![]() ![]() ![]() ![]() ![]() Posted: October-05-2019 at 7:23am |
I have had a play with the foam.. some things I did on my 78 SN pages 2 and 7 you may consider should you go with foam on your build, I found cheap DPM used in concrete floors works well as it will shrink around the foam once the foam has set with a cheap heat gun.
Good luck with it and thanks for saving a Gen 2 SN Roger |
Lets have a go
56 Starflite 77 SN 78 SN 80 BFN |
MrMcD ![]() Grand Poobah ![]() ![]() Joined: January-28-2014 Location: Folsom, CA Status: Offline Points: 3778 |
Boy, it has been nearly 30 years since I carpeted my 78, I don't remember anything looking like the pictures you have. I just pealed the old carpet out cleaned the flooring spread the glue and installed new carpet. It turned out great and still looked great when we sold it several years later. I think we were about 1,000 hours at that point, sold it at 1,500 hours.
Great boat. |
Evilsizer ![]() Groupie ![]() Joined: August-29-2019 Location: Ohio Status: Offline Points: 62 |
JoeinNY ![]() Grand Poobah ![]() ![]() Joined: October-19-2005 Location: United States Status: Offline Points: 5698 |
I dunno Pete - I still see no evidence of the wood over foam method being anything other than the worst of both worlds. Heaviest, most expensive, and most likely to rot. Maybe slightly easier/faster than foaming/cutting/glassing if you don't spend much time fitting the plywood panels - maybe slightly safer than wood with no foam. Having some skin to keep some water out seems like it is a non factor where that skin either would be either be a cut surface that is filled by resin/cloth or where the foam wouldnt exist under plywood to get wet anyway. By far the most rotten falling apart piece of crap boats I have ever torn into were plywood floors with foam injected under them. |
Andrew, Understand that many do go no foam and plywood and that's an option. If you do go foam, I actually prefer going with plywood and injecting the foam. When the foam is injected into a sealed cavity, the outside surfaces of the foam form a skin without the tiny air pockets (cells). This skin is an added barrier to water compared to the cut surface foam that opens the cells. |
Could I put down a piece of plywood with wax paper on the bottom side. Drill the holes and pour the foam then remove the plywood. I think the wax paper will keep the foam from sticking and then it will be flat
8122 what's this injected foam you speak of
So what's you advise? Wood floors or go back to foam and glass
Ya its mobile
Andrew, What are you trying to use? Mobile devices don't work. |
I cant post pics. I have tried. Even gone to the top of this thread like people say.
MourningWood ![]() Gold Member ![]() Joined: June-13-2014 Location: NorCal Status: Offline Points: 920 |
When I visited the CC factory in 1983, I was amazed to see the open hulls, with the foam poured and hardened in place, outside the shop.
Workers were sawing the foam 'flat' with hand saws before going back inside for the glass-over 'hard' floor. The foam chunks were tossed into a dumpster. Seemed somewhat 'primitive' to me, even by 1983 standards... |
'I measured twice, cut three times, and it's still too short!" |
TRBenj ![]() Grand Poobah ![]() ![]() Joined: June-29-2005 Location: NWCT Status: Offline Points: 21198 |
It wasn’t built that way at the factory. |
Andrew,
How about posting some pictures of your project? |
I owned a 1978 Nautique, In about 1986 I put new carpet in that boat. My carpet installed over a wood floor front to back.
Mark |
Yes I have looked. I have not seen any examples of glossing over the foam for the floor like Correct Craft did. Did they por it and then shave it down flat with something? Then glass it?
I'd say they didn't pour but rather use plural equipment. Ether way, after the foam cured it would be sawn flat.
Also
Hey experts! I have a 78 SN I'm doing a stringer project on. In my boat they just fiberglassed over the foam to make the floor. There is wood up front under the bolted down seats and ski pylon. How did Correct Craft pour the foam in flat to then just glass over it?
