reverse rotation distributor 454? |
KENO ![]() Grand Poobah ![]() Joined: June-06-2004 Location: United States Status: Offline Points: 11197 |
![]() ![]() ![]() ![]() ![]() Posted: November-27-2019 at 7:31am |
Oh Boy, this must be a Rosco mystery thread...!
rosconole ![]() Gold Member ![]() ![]() Joined: May-10-2008 Location: United States Status: Offline Points: 760 |
Its already got PCM kit ,but this is for something even better than that....!
1989 ski nautique ,1991 barefoot nautique, 1993 Mustang Cobra 1998 5.0 Magazine shootout invitee
some guy in CA bought the pro technology like a year ago on ebay for 150 plus freight LOL i almost spit my dinner out when it sold.
Air206 ![]() Grand Poobah ![]() ![]() Joined: September-28-2008 Location: Roanoke, VA Status: Offline Points: 3004 |
Keno is correct. The PCM 454 reverse rotation engines take a standard rotation distributor.
I went with a marine DUI from Performance Distributors. Great service and amazing turn around time if you happen to find you need to return the reverse rotation unit for the standard rotation! ![]() Wiring is super simple. I used almost all of the pro-tec harness to make the install neat. I have 454 pro-tec wiring specs if you are swapping out a pro-tec. I've tried to upload several times to the site. They should be around somewhere. |
How about one of what's in the link.
It says for standard rotation only but they're talking distributor rotation not engine rotation The distributor in let's say your reverse rotation BFN turns in the standard Chevy clockwise direction and it uses the same gear as a normal rotation Chevy. cause they did reverse rotation engine cams different than Ford did. The cam turns the same direction for normal and reverse rotation. it makes for a long, convoluted, often misunderstood story You could buy a reverse rotating Chevy distributor from them, but you couldn't make it fit with a sledge hammer ![]() I can't remember who got the wrong one and had to return it, well actually I can but maybe he'll come along and tell you about getting the wrong one link |
what aftermarket distributor are you guys using for 454 that seems to work were outside of a stock replacement , what kinda gear does it need?
