14x14x16 1 1/8 3 blade RH prop |
Author | ||
rosconole
Gold Member Joined: May-10-2008 Location: United States Status: Offline Points: 759 |
Posted: February-29-2020 at 2:51pm |
This is the correct information
14 RH 16 Cupped 1.125" Bore. OJ Propellers 1052 Legend 3-Blade Ski Boat Propellers. The name speaks for itself. The OJ Propellers Legend is exactly that- something incredible handed down form one generation to the next. What began as Oscar Johnson's dream, OJ Propellers has been redefined and perfected until it has emerged as the professional's choice in original tournament boat equipment. |
1989 ski nautique ,1991 barefoot nautique, 1993 Mustang Cobra 1998 5.0 Magazine shootout invitee
67 ski nat
Platinum Member Joined: July-19-2018 Location: Santa rosa Status: Offline Points: 1194 |
Wow that’s a crazy prop
According to google that prop will move you 64” every rotation At 3500 rpm your boat should be going 212 mph Y’all are fast in Florida |
Orlando76
I seen a listing for a 14x14x16 for sale in Orlando. Lots of metal missing on it. When all the metal was there It might’ve been a solid 14x14x16x16. Maybe even a 14x14x16x16x18.
Or was it a 14x16 and they took metal off to make it a 14x16? |
67 ski nat
Good thanks for explaining
The pitch is the theoretical distance the prop (boat) will travel forward or reverse without any inefficacy due to slippage. Pitch blocks are wedges typically wood that are placed next to the prop blade to check the angle. They are specific to the pitch/angle and are what prop shops use when rebuilding or changing the pitch of a prop. Now the more sophisticated method of measuring is laser scanning. |
67 ski nat
Of course, cheese and snarkasim go well together
It is just a big screw (threads per inch or inches per one thread) |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11116 |
Time for a little snarkasm Daryn No it's impossible and it's just an arbitrary number that gets dreamed up . But anyways It's not the most straightforward thing to do. Google is your friend. PS .....................Cheese on the burger would be good |
67 ski nat
Can the 16 pitch be measured accurate
So it must have some kind of identity crisis. It doesn't know if it's a 14 X14 prop or a 14 X16 prop |
rosconole
it was NOT repitched. they stamp their own numbers on it for reference when they balance it for whatever reason.
But you don't know what you have there.
Through the magic of the internet, I see your prop pictures someplace else with all kinds of funky markings. I figure it got repitched and restamped. |
rosconole
I needed a HP calculator to figure out all the stampings |
Roscoe With all those numbers that's gotta be ultra super duper high performance. Maybe it's one of them there fancy duo prop setups |
Darn, I need a 14x14x16x16. So close.
rosconole
14x14x16 1 1/8 shaft RH prop 3 blade OJ or federal just refreshed 150. venmo and zelle accepted.
