High rpm at idle |
eric lavine
Posted: September-30-2006 at 9:29am |
hey tim, good point but it also tears up that thing behind the damper also, it creates alot of pre-mature (i know you guys know that word) wear on the teeth of the clutch plates. it may also cause warpage eventually in the plates because they are grabbing at such a high idle and can not dissapate the heat quick enough, plus it may even lead to the reverse or reverse plates snapping in half
LakeBoy
Gold Member Joined: July-19-2006 Location: Roseville, CA Status: Offline Points: 709 |
Does the 99 gt-40 have a throttle body?
Tim D
1400 rpms at idle is a good way to ruin the damper plate.
Tim D
todicus
Senior Member Joined: July-10-2006 Location: Napa, Ca Status: Offline Points: 493 |
Turn your idle set screw counter-clockwise to lower the rpm in neutral. It's located on the trottle body just below the throttle cable connection.
Buoy-boy
Newbie Joined: September-24-2006 Status: Offline Points: 3 |
I have a 99 ski nautique with the GT-40 engine. I just got it and now noticed that the rpm is running high rpm...1400...at idle when in nuetral. When in gear, the rpm drops to about 700 which I believe is normal.
Is there an easy way to lower the engine idle when in nuetral? Otherwise, what is recommended? Thanks |
