Hooked up batteries backwards |
td_in_nc ![]() Senior Member ![]() Joined: March-30-2012 Location: Clayton NC Status: Offline Points: 381 |
![]() ![]() ![]() ![]() ![]() Posted: April-11-2020 at 11:07am |
I made that mistake once - do as suggested about and see if you getting power at busbar, key and starter, if not then trace it back. Hopefully a blown fuse. Good luck
Nautiquehunter ![]() Platinum Member ![]() ![]() Joined: December-31-2008 Location: Lake Lanier GA Status: Offline Points: 1010 |
I think that model had a fuse link on the smaller pos wire near the battery. Check to see if you are getting power at both side of the battery wires.
Chris5084 ![]() Newbie ![]() Joined: May-23-2017 Location: Arkansas Status: Offline Points: 7 |
Big bonehead move......I hooked one of my batteries up backwards. When I tried to turn the perko switch, it froze/welded shut. I think the switch by the drivers seat was set to all on too.... The other battery was hooked up correctly. Once I realized what I had done, I quickly removed all connections.
I removed the perko and tried hooking up a good battery (both the ones during the mess-up, won't hold a charge). The hour meter reads O and it won't turn over. I have checked the three fuses by the red 60 and relays. I am attaching a picture of the two relays that tick/click when I push the start button. 2004 Santa 210 330 pcm Sorry if this doesn't make sense....I'm spazzed and pissed that I did this. |
