I GIVE UP, calling in the big expensive guns. |
Post Reply | Page 12> |
Author | ||||
gun-driver
Posted: May-23-2020 at 10:27am |
Yea don’t forget to add the 99% humidity the bugs the gators the hurricanes and the blue hairs |
Orlando76
gun-driver
Hence the reason not to live in that hell hole |
Orlando76
Park it in the shade. No sense fighting the Florida sun.
NautiqueHack
Newbie Joined: July-25-2019 Location: Orlando Status: Offline Points: 21 |
Smart boater!
I already had the tank out and I never checked these lines, duh. I did replace all the fuel lines and steering cable so I did some of it. Wish me luck that I don't have to tear into this too much in the Florida sun. |
desertskier
Platinum Member Joined: December-19-2006 Location: Az Status: Offline Points: 1115 |
I just replaced the hoses and pumps going to the hard tanks on our '99. The hoses were cracked at the hard tank fittings and underneath the muffler. I just disconnected the hose at the thru hull fitting and used a garden hose to find the leaks. The bad news is for our boat I had to pull the fuel tank to be able to replace the hoses. PITA but while I had the tank out I installed a new steering cable and greased the rudder. The drain and fill fittings are on the bottom of the tanks. Yours is newer so you may get lucky and find the leak before the hoses go under the tank.
92 SN - Owned since 93
99 Pro Air 89 SN - Went to live on a lake in Texas 75 Donzi 16 - Sold in 93 |
NautiqueHack
Problem found (kinda) and solved (band-aid).
Somewhere in my ballast fill system I have a leak. When cruising water is being pushed in past the pump and draining/leaking into the aft compartment. It's a pretty big leak and these hard tanks are not helping me figure out where it's coming from, can't see anything! The easy fix to take the wife and kids for a ride is that I closed the ball valve in the engine compartment until I have some time to start taking it apart again and diagnosing the failed parts(s). I was out in it today on my lunch hour, ran it up and hit around 40 mph. To be honest, I was thinking this boat would do more than that. I wasn't pushing it (4500 rpm) so I'm not sure. I don't think I have any reason to go that fast, more a curiosity than anything. |
ShyDookie
Newbie Joined: March-30-2016 Location: Hoover, AL Status: Offline Points: 5 |
GottaSki
Is the bilge water warm?
River Rat to Mole |
NautiqueHack
Correct engine rotation, check.
The water is a little strange so far. It really only enters the boat when I'm running. Sitting in the water and idling there is not noticeable water intrusion. If I run around the lake, boom water in the aft of the boat. I'm thinking it could be from the rudder leaking or....well I don't know. More investigation is needed. |
Orlando76
Orlando76
1-2 minutes? Wow that’s ALOT of water.
NautiqueHack
Well, it's back! After a month at the shop the fuel injectors were the problem, all 8. They were removed, sent out for a rebuild, and now runs like a champ. I threw an alternator belt but that was my fault for not looking at the alignment of the pulleys, that will remedied this evening.
Now, this boat has never floated on my watch. We slid it in the lake on Friday and ran it for a little while. I did find out we are taking in too much water to be comfortable. The bilge will run for about 1-2 minutes after a 5 min run around the lake. The search for the water starts. |
SNobsessed
Squirt some gas (like less than an ounce) into the manifold (put flame arrestor back on) & see if it comes to life.
IIRC there is an inexpensive fuel injection relay that can fail. |
NautiqueHack
Thank you again for the thoughtful response! Last night I verified my timing is correct. What I found interesting is that none of my plugs were wet. I assumed since I had fuel in the rails, pumps were working that I was getting fuel. Now that I have eliminated the timing issue my focus leads me to injectors clogged and not working? A little more history, the gentlemen I purchased the boat said it has not ran in years. The date on the oil filter was somewhere around 7 years ago so there is no telling when this engine ran. The tech is slow and I won't be able to drag it down there until tomorrow, I might try and test the injectors this evening after work and see if they are seized. I wouldn't think all eight would quit but after years of fuel sitting in them, they could be gummed up. |
zwoobah
Senior Member Joined: September-13-2018 Location: Providence RI Status: Offline Points: 308 |
Unburnt fuel in the exhaust does make for interesting noise, and potentially popped mufflers. Little different than a backfire but can be caused by the same issue. |
1968 Mustang 16 - 351W powered
Donald80SN
Grand Poobah Joined: January-12-2009 Location: Denver, NC Status: Offline Points: 3896 |
On this site, there is a GT-40 trouble shooting guide.
Riley
Turning the ignition off for a few seconds then turning it on when cruising through a tunnel used to make a pretty loud noise out the exhaust.
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11093 |
I guess you would call that loud noise out the exhaust that can happen when the timing is wrong, something else then? My wife says I have some fundamental issues cause I can backfire from my mouth and my a** at the same time. I just belch and fart and tell her "it's a guy thing" |
NautiqueHack
NautiqueHack
https://en.wikipedia.org/wiki/Back-fire |
Hollywood
A backfire doesn’t go out the exhaust. You’ve got some fundamental misunderstandings and it’s time to get help.
Back in August of 2019 in your first thread, somebody local seems to have volunteered to help you out.
I think he knows his way around an engine Here's a quote from that thread
MrMcD
Grand Poobah Joined: January-28-2014 Location: Folsom, CA Status: Offline Points: 3749 |
Thanks(1)
Keep in mind that the engine will be on Top Dead Center twice in each complete cycle.
Once for exhaust stroke and once for Compression stroke. you can pull the spark plug in #1 and put your thumb or a compression tester in the hole. Now rotate your engine slowly and you will feel the compression building or see it on the gauge when you approach TDC on the compression stroke. As you look down on the front of your engine below the distributor in your Ford you should notice one of your Heads is about 1" forward of the other head. The First plug in this forward head is your Number 1 cylinder. As you feel compression building start watching for your timing mark to come and align the harmonic balancer line with the TDC mark on your engine. Top Dead Center at your Zero mark. Once engine really is at TDC you can pull the distributor cap off and make sure your rotor inside the cap is actually pointing at the #1 plug wire on the distributor cap while you are at TDC. If the Rotor is not at #1 you need to adjust. At this point if you are off you have two options. Move the Plug wires on the cap to the correct spots based on where your rotor is pointing or unbolt your distributor and lift it up to rotate the rotor to the place you want #1 to be pointing, as you drop it back down you will notice the rotor moves as it settles in, this is normal you just have to try a couple spots till you get it pointing to the spot you want. The engine does not care where #1 is located as long as the rotor is pointing at the #1 plug at the proper time and all the following wires are in the correct order for your Engine and they circle the distributor cap in the proper direction your rotor will spin. It is always a good idea to have your #1 be in the same spot the factory set it at so the next wrench to touch your engine has an easier time. |
What Tim is leading to is you put #1 piston on it's compression stroke- pointer on the timing cover will be at TDC on the harmonic balancer. Then as you drop the distributor into place make sure the rotor points to #1 position on the cap as close as possible. If your off a tooth one way or another you will be able to adjust for that.
And therein lies the problem
NautiqueHack
I used the diagram in the nautique manual. |
How did you determine where to put cyl #1 (on the distributor)?
NautiqueHack
Fill us in a little more please did you end up replacing the block or did you have it rebuilt? Was the distributor taken out of the block? And yes you can use a timing light put it on #1 cylinder and see if your getting spark ie the light will flash and see where it flashes on the harmonic balancer's timing marks, should be somewhere near TDC. A GT40 has to be adjusted to the proper base setting for the ECM to adjust from there, There is also a procedure to time it to base as well. If the distributor wasn't put in the proper way in the first place this very well could be your troubles.
