  New Posts New Posts RSS Feed - Pertronix conversion question
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Topic: Pertronix conversion question
    Posted: May-07-2020 at 6:34pm
Is this an Ignitor or an Ignitor 2 that you installed?
The Ignitor 2 seems a little sensitive to voltage supplied to it while starting the engine. If it's low they crank a little longer. If it's low enough (8 volts) it won't fire at all.
How is it wired? I imagine you've bypassed or removed the ballast resistor
What's the voltage going to the coil/module while cranking the engine before it starts?
And did you read and follow the installation instructions? I don’t remember if it’s points or certain EI modules that get full voltage during cranking only, then a resisted supply while running.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: May-06-2020 at 9:27pm
Originally posted by burban65 burban65 wrote:
Pete and Keno on the same forum topic / thread.........best part of my day so far
You, you, you're such an instigator, glad to make your day good so far
burban65 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote burban65 Quote  Post ReplyReply Direct Link To This Post Posted: May-05-2020 at 12:10pm
SRB
Post Options Post Options   Thanks (0) Thanks(0)   Quote 67 ski nat Quote  Post ReplyReply Direct Link To This Post Posted: May-05-2020 at 11:33am
Pertronix recommends NO ballast resistor and use there flame thrower coil has proper ohms
You could see if your coil has same ohms as flame thrower
I did full billet body conversion. Works fine
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: May-05-2020 at 9:37am
So Pete.............why do you tell people to stick with points but you still have that electronic module in your Tique.?
What's in my Tique has nothing to do with my suggestion to Tom. In the very first post, he said:
Originally posted by dockedwages1 dockedwages1 wrote:
With points it seems that when boat was timed perfectly, if you barely touch the key it would fire right up.
I didn't ask why you told Tom to stick with points, I asked why you tell people (pretty much anybody who says they swapped or are thinking of swapping) that they should stick with points, but you have an electronic setup in the Tique
There must be a reason you don't swap back.
I guess you're just that "do as I say, not as I do" type
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-05-2020 at 9:04am
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: May-05-2020 at 8:05am
Installed pertronics electronic ignition conversion on 82 351w last week. Very easy install. Boat starts up a little slowly. Once it was running I put timing light on and set to 10 degrees btdc. It runs great, great response up to 40 mph. But after I turn it off and restart it’s a little slow to start. Should I be timing that engine differently with the conversion? With points it seems that when boat was timed perfectly, if you barely touch the key it would fire right up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: May-05-2020 at 7:52am
Tom,
Setting the timing is the same as with a point set.
I'd put the points back in! Why did you do the EI conversion?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-04-2020 at 10:45pm
Tom,
Good it cranks fine. The reason I asked is a slow crank indicates a possible timing problem.
dockedwages1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dockedwages1 Quote  Post ReplyReply Direct Link To This Post Posted: May-04-2020 at 10:39pm
No it cranks fine it just takes a couple turns to fire. Don’t worry I kept the points and everything in a ziplock bag because I’ve heard that these conversions fail also!
Post Options Post Options   Thanks (0) Thanks(0)   Quote dockedwages1 Quote  Post ReplyReply Direct Link To This Post Posted: May-04-2020 at 10:35pm
Pete you know what I did? Exact what I learned on this site to not do. Throw money at parts instead of finding the problem. Ive gotten very familiar with a multi meter in the past two years and what voltages should be where on this engine. And I’m tired of replacing condensers, points, coils and voltage regulators that don’t have 20 hours on them. Some of these parts regularly arrive non functioning. And I haven’t been buying them from a local auto parts store. So I’mm h h ping to give this conversion a shot for a month or two and see.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-04-2020 at 10:25pm
Tom,
When you say it "starts up a little slowly", do you mean it cranks slow or takes more cranking before the engine fires up?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-04-2020 at 9:44pm
Tom,
Post Options Post Options   Thanks (0) Thanks(0)   Quote dockedwages1 Quote  Post ReplyReply Direct Link To This Post Posted: May-04-2020 at 9:27pm
