Bought a set of junkyard GT40P heads |
Marseille
Newbie Joined: April-24-2018 Location: Jax Status: Offline Points: 19 |
Posted: May-28-2020 at 7:37pm |
Apparently this is the most aggressive. How is this grind any different than the stock 351W grind?
STD 351w camshaft specs Duration @.050" (I/E): 206/221 Lift w 1.6 Rockers (I/E): .445/.453 LSA 115° Comp Cams Spec: Duration @.050" (I/E): 206/212 Lift w 1.6 Rockers (I/E): .443/.452 LSA 112+2° |
'83 SN
Meh that’s hardly any warmer than stock. The CR cam is a little better at .460, just tell them you want the most aggressive rh cam they can make. Last
I heard the .460 was it based on the blanks they had. Ideally it’d be closer to the .490-.500 range with p-heads but some 1.7’s would get you pretty close. |
Marseille
I'm not either. The guy at CR made it sound like he wouldn't be able to help me. So I called Comp Cams. Alex was helpful and indicated they had few RR blanks left. He said after they are gone....they are stopping the program. Here's what he said he could do. Any feedback?
'83 SN
Not sure why we are “dreaming” since the HO 351w made 92-02 was rated 285-310hp with 8.6:1 compression and a .445 lift flat tappet cam. P’s flow just as good as the regular GT40’s and offer about a point of compression increase on a stock bottom end. Add a slightly warmer cam (like CR’s own .460 grind) and a decent intake and 325hp is pretty commonplace. That’ll push a 2nd gen SN into the low 50’s or better, and have an early 2001 flirting with the 50mph mark.
You probably talked with Scott at CR. Despite knowing fords pretty well and making some decent cams, some of the “knowledge” regarding ski boats over the years has been... well, slightly off the mark. The above referenced build is well proven and pretty tame compared to what some others here have built. Tried and true and a nice upgrade over 240hp no doubt... but if you want reliable 50+ you will need a bit more power in that hull. In terms of exhaust manifolds, some pictures were posted of a cross sectioned PCM pyramid and they’re actually a pretty nice flowing design. We’ve seen some pretty good performance out of log manifolds on lighter boats too- so while certainly suboptimal, you can still make them work. I’ve got a 331ci p-head engine at 10.3:1 and a cam not far off what CR offers and it’s running almost 10mph faster than stock. |
Marseille
I spoke to someone at Cam Research today. Failed to get the name. He asked about goals and I suggested 300+ HP and 50mph. Apparently, folks are dreaming if they think they are making 300+ HP with 40P heads, an intake, and a camshaft. He continued: "the exhaust manifolds are a bottleneck and the length of the exhaust run to the transom is too short to provide you any benefit." This information seems to fly in the face of what's been commonly accepted here regarding increased power levels with heads, intake, and camshaft swap.
'83 SN
Marseille
Haven't decided on a cam. I was thinking about giving Scott? at CR a call for a cam and lifters. Someone last year listed this part number CR112016 @ $285 for the cam and lifters. Not familiar with como cams.
Painted one of the heads 1601 (Old Ford Blue). Did I screw up by not masking off the exhaust gasket location? |
'83 SN
Mille1sj
Senior Member Joined: October-01-2007 Location: United States Status: Offline Points: 278 |
I went with the Performer Intake for room. 1.6 roller rockers and lifters. You will definitely be happy with the GT40P heads. Have you decided on a cam? I know a lot of the guys on here work with Cam Research for anything Ford. Como cams would be another good option.
You won’t find a Reverse Rotation roller cam on anyone’s list but they can be made if you wanted to go that route. Expect to spend more money on it. I had one made for our 77 Ski Tique. You would need a new distributor gear, but I know a guy that has those. |
Marseille
Guys, I really appreciate all of the feedback. It's extremely helpful and valuable as I navigate through the options. I'll keep updating as I acquire more parts for the head/intake swap. I like the idea of keeping it simple. That KN filter sure is nicer looking than the stock SA.
In other news, I purchased the Acme 540 today. It should arrive by the weekend. Seems like a lot of people around here were really happy with this purchase. Right now she is running 46mph on the GPS. |
'83 SN
Jonny Quest
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2957 |
Tim is correct. The K&N has a 2" element and has a 3.75" total height. In my application, I tried to re-use the PCM spark arrestor, but it was much taller than 3.75 inches. My unit came off the throttle-body injection system and was about 5" tall. That's why I went with the K&N. Skidim has a spark/flame arrestor for $70 that is 2.5" tall. That may work for you. As Tim also pointed out, the newer carbs should have a full manifold vacuum port at the base of the throttle body -- good for your PCV valve.
My 1994 (NWZ hull) engine box will be different than yours. To check fitment, I took a big ball of soft modeling clay and placed it on top of the existing set-up and then closed the engine box lid. I measured the "squish" on the clay and I was able to determine how much "headroom" I had. LINK to K&N Unit JQ |
phatsat67
You would likely be ok clearance wise if you set up a wedge like Tim said above. I also do not like putting the PCV on an individual port. Aside from running a cylinder lean potentially you'll run every bit of oil vapor into that cylinder rather than spreading it over several.
We were able to keep the factory throttle cable mount on my brothers boat. It works ok but I may end up swapping out to one of the sandwhich style cable mounts that goes under the carb. Works great on my BFN setup. Straighter shot on the cable and much better adjustment potential. The bracket in the link below comes with two gaskets and a mount that is compatible with the Morse style cables (Just like the one on your transmission cable). Throttle Cable Bracket Also, even with the stock spacer we were able to bend the factory fuel line to work perfectly fine. I assume if you use a wedge on the RPM a similar setup could be had by tweaking the stock fuel line. |
FYI, k&n doesn’t make a “low profile” marine arrestor. The shortest they offer is 3.75” tall and is taller than most factory flame arrestors. k&n marine You would be better served finding a real low profile arrestor or cutting down your element if trying to increase motorbox clearance. The min is usually 2” to clear the holley j-tubes. Newer Holleys and QF carbs have vacuum ports in the throttle body. Otherwise I’d try a small wedge plate and add a vacuum port (this will increase clearance vs the tall pcm spacer). I don’t like the option of putting it on an individual runner, though others have done so. Zach is correct about the performer vs rpm... though the rpm is definitely better, that extra inch of height becomes especially problematic on the 2001 (83-88) box- it doesn’t have as much room underneath as the NWZ box (89-95). |
phatsat67
Shane, late to then party here. Pricing for the work seems reasonable. Also, great show called Engine Masters by Motortrend. Couple weeks ago they did some intake testing on an AFR 185 headed stock stroke 351 Windsor. They ran the regular performer and it made somewhere around 425 hp up around 6000 rpms. They swapped to an RPM and only made another 10 numbers or so at peak.
For that engine and RPM requirement I wouldn't even mess with a performer RPM and open myself to potential clearance issues and monkeying around. We run a standard performer on my brothers 89 SN with the stock spacer and flame arrestor without clearance issues. Id, go that route. The only oddity we had with his intake is it had an EGR hole cut in the exhaust crossover. Make sure if your intake selection has that you get the block off plate and a proper gasket from Edelbrock. Some later carburetors have an extra port for the PCV but the normal small block 600 generally does not. Stick with the stock spacer and you won't need to reconfigure anything. |
Marseille
Thanks JQ! If I delete the carb spacer, where do I connect the vacuum hose for PCV valve from the starboard rocker cover? Where did you source the low profile K&N ? |
'83 SN
Marseille
Those heads look like a good deal.
Here are some pics after the machine shop work. |
'83 SN
Duane in Indy
eBay item number:303553555780 Complete Aluminum Cylinder Heads SBF fits Ford GT40 289 302 351W 190cc 62cc
Saw these today while surfing. Know nothing about them other than what is listed. Good way to shed 40#. 62cc chambers might be a little an the big side for compression. IIRC mine are 58cc, I could check. If they are compatible then that is a whale of a price. |
1978 Mustang (modified) |
Jonny Quest
Silicone -- I like Permatex Ultra Black for the China Wall Head Bolts -- Ask 10 people, get 12 answers. I like to go with new ARP head bolts Intake Manifold -- I would go with the Edelbrock Performer RPM (7181) if you can fit it. On my 1994, I was able to fit the RPM with a low profile K&N filter/spark arrestor. You could also delete the carb spacer if needed. I removed the spacer with the RPM to make it all fit. If you can't fit the RPM model, the Performer (2181) is a great manifold also. If you do go with the Edelbrock manifold, I found that the Edelbrock gasket 7219 fits better than the 7220, which is mentioned in the installation instructions. (thanks to KENO for this recommendation). Another good choice for intake gasket Fel-Pro a 1262-S3 Intake Manifold Gasket set. JQ |
Marseille
Yes, they replaced them with brass plugs.
'83 SN
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11061 |
Back to your previous post, most any oil resistant RTV will work on the "china wall" and the bolts can all be reused. The head bolts on a 351 aren't torque to yield.
Some people throw them out and replace them, some use them over and have money for other stuff. Your choice Did they replace those round plugs in the ends of the heads with brass ones like Gary mentioned? |
Marseille
Heads back from the machine shop. They charged $330
Valve job Pressure tested drill 1/2 " head bolts seals |
'83 SN
Marseille
I only set the timing at idle. Should I be adjusting it at a higher RPM and or closer to 10 at idle? The advance springs I installed are fairly light meaning they're not very stiff. It seems like timing advances fairly quickly. I have other springs but they don't seem to be as easy to install or match up as well as the ones I installed. The ones in there now are definitely better than what I had which equaled none. Keno, thanks for the gasket kit part no. Any particular silicone on the china wall? I was planning to get new bolts for the heads, intake, and rocker covers. Put the $ elsewhere? Regarding intakes, which is the better choice, and will it fit under my engine cover with a stock flame arrestor? I do have the stock PCV spacer under the carb. The Edelbrock Performer 2181 @ 4.120" manifold height or the Performer RPM 7181 @ 4.800" ? Older threads from 2006 & 2007 seem to indicate a lower profile 2" or 3" FA is required for certain aftermarket intakes. |
'83 SN
You can get a Felpro marine gasket set 17261 that has what you need . It's for use with cast aluminum valve covers like you're planning, as compared to their 17260 gasket set which is the same and has different, quite a bit cheaper valve cover gaskets for stamped steel valve covers |
gun-driver
Wow nice clean manifold bolts and what a purdy color don't ya think Joe
You may be leaving some performance on the table with that timing. |
Marseille
Gary and MCO76,
Thanks for the feedback. I dropped the heads off at the machine shop and they will let me know fairly quickly if they have any issues (cracks, etc.) and if they'd be able to help me. Otherwise, they said they would know what they needed once they got into them. About a week out until I'll hear something. Maybe sooner. Here are the current oil leaks. Shane |
'83 SN
Orlando76
Just for reference I swear Clearwater Cylinder charged $350 for GT40p hearts drilled for 351 4 years ago and I kept my core. Seems like too good of a deal to be true. But memory fades as I’m getting old.
Be careful on cylinder head work- money adds up real quick. By the time you have them checked for cracks,surfaced, the seats cut,any valves replaced, springs checked and or replaced,spring height checked, guides checked,repaired/replaced money doesn't go far. You will need brass core plugs, and the bolt holes drilled out to 1/2" for a 351. Ask what they feel needs to be done to refurbish them and let us know how much their talking
Marseille
Good Morning CCF's,
I believe these heads are off a 1999 Mercury Mountaineer. I picked them up yesterday for $135 out the door. Not sure if I got a decent deal. My plan is to take them to a machine shop and have them rebuilt? I'm a noob when it comes to engine work. I have been reading a bit in the archives but overwhelmed with information around 1.6 roller rockers, pushrod lengths, springs, valves, RR camshafts, less than .500 lift, .210 in .220 out. 110, 112, 115, pulling water into the engine via the exhaust with too much LSA, etc. Could someone be so kind as to give me an idea of what I should be asking the machine shop to do to them? I'm pulling off the old heads because I have oil leaks from the heads, rocker covers, or both. Any recommendations on gasket kits? Fel-Pro ? Replacing rocker covers with aluminum ones. M-6582-A301R My short term plan/goal, for now, is to install rebuilt heads, rocker covers, and intake (RPM performer?) with new gaskets to seal up the motor from any leaks. Background: 83 Ski Nautique with 351W that I picked up a couple of years ago. I've performed all of the routine maintenance and upgrades myself. 1023hrs New plugs and wires 2019. Fully rebuilt carb by National Carb 2019. Impeller 2019 Belts 2019 All hoses 2019 Installed fuel filter 2019 1 wire alternator New throttle and trans cables 2019 Oil, filter, trans fluid change 2019 & 2020 Converted to Pertronix 1.5 ohm coil and ignitor EI 2020 (Prestolite clip dizzy) Added springs to timing advance weights (one missing, one fully stretched) Set timing to 8 degrees BTDC at idle goes a little above 30 advanced Adjusted carb. Idles at 650-700 and 600 in gear. Pulls 15 inHg of vacuum slight movement of the needle not rock solid. Boat feels pretty good as is. |
'83 SN
