First time buyer questions |
zwoobah ![]() Senior Member ![]() ![]() Joined: September-13-2018 Location: Providence RI Status: Offline Points: 308 |
![]() ![]() ![]() ![]() ![]() Posted: June-11-2020 at 7:10pm |
The black/dark blue $500 one was a Mustang SS. Stringers completely rotten and motor was locked up. It's currently being parted out in the Classic Correct Craft group on facebook.
If you're used to a jet boat you'll probably be OK with the ride of an early Mustang. Watch the lack of freeboard at the rear if you're carrying passengers. Easy to take some water over the side. |
1968 Mustang 16 - 351W powered
Mustang1 ![]() Newbie ![]() Joined: June-06-2020 Location: S New England Status: Offline Points: 6 |
yeah the appeal is the Mustang's shorty look. I'll end up with a mid-60's Mustang. may take a while. prob exactly the wrong time to buy anyway!
btw there was just one near me for $500 needed motor, but who knows what else was wrong. it went too fast to even go look saw a few in the 3500 range, but now the prices seem up and I like to find a bargain even if it takes longer. |
I disagree. Same shape of hull only 2' longer. Same characteristics as the Mustang. Hard ride on rough water and the porpoise issue. |
The motor swap was done before I owned it - previous owner didn't properly winterize the 289 and the block split.
These aren't good rough water boats. The flat bottom means they porpoise like crazy in light chop. You might want to consider a Barracuda - vintage look in a hull that can take some chop. |
zwoobah, thanks. did u see a bump from 289 to 351? better hole shot/ top speed?
I'm actually glassing some small ribs in an old boat now and using vinyl ester resin which has advantages over epoxy and very good bonding. The cool thing is I use no-wax formula (laminating resin) which requires no scruffing between cured layers, but also doesnt stay sticky at all.
BUT I am no where near able to take on stringers. I had a jet boat once and paid for stringer job by a guy I knew who is a pro. The work was fantastic. Strong, thick, and looked factory. I learned what a "pro" is from seeing that. But today, that job is pretty big $$$. So yeah, need to get one with good stringers. I plan to run mine on the bay, sometimes coming back in the chop. Has to not be coming apart. |
I have a '68 Mustang on a lake in NH. There are a few Mustangs for sale in New England - check facebook marketplace.
I've had mine for 1.5 years. Stringers are the biggest issue to check. Tapping - like Donald suggested - is a good place to start. You can also try tightening the engine mount lag bolts. They should feel very firm. If they are loose or spin you know the stringers are rotten. Soft spots in the floor are a sign of floor rot, but if the floor is rotten the stringers are also usually rotten. The engines are mostly automotive engines with an added raw water pump, and adapted to spin in reverse. If you can work on an older car engine you'll have no issues with these boats. Mine was originally build with a 289 but later had a 351 swapped in. This required cutting and widening the engine cover. It's now good for 51mph but is a little unstable getting there. |
Donald80SN ![]() Grand Poobah ![]() Joined: January-12-2009 Location: Denver, NC Status: Offline Points: 3896 |
The wood rots and you are left with fiberglass that comes loose from the wood and your motor lag bolts will no longer get tight. The floor also gets soft and caves in. You will know it when you see it. You can tap a hard object like a wrench on the glass over wood stringers and listen to the sound and it will tell you if the wood is rotten. They use boat resin or general purpose resin on the stringers to save money. Over time, water travels through the glass and stays in the wood. Early boats also may have gel coat issues on the bottom if the boats were left in the water over time. Fiberglass was new in the early 60's so there can be issues.
It is recommended that when you do a stringer replacement job, you used epoxy resin. It is more expensive but does not let water travel through it over time. Just search stringer replacement. Several projects should appear. |
Thanks, I am looking for the old school look and the 74 looks too modern! Plus its very far away. No rush just learning now. Thats good about early stringers. What does a bad stringer look like? Actual separation?
Also, I am surprised at the different engines these seem to have come with including 318 poly!!! I need to go see one thats reasonably close, RI/MA/NH and also get a ride. |
The primary and the secondary wooden covered in glass stringers are the thing to look at. In the early boats, Correct Craft did not use foam between the wall and stringers to add flotation and make a floor. Fiberglass over foam makes a nice floor, but the foam hold water and rots out the stringers. Most of the early CC boats did not have foam so the stringers hold up well. However, you still need to check them out. Stringer jobs are doable, but are a big project.
Top speed is about mid 40's. These boats were built for pulling skiers and they are more about torque than speed. They sound like they will run 70, but most run less than 50. |
Fabcon ![]() Gold Member ![]() ![]() Joined: August-27-2012 Location: Buffalo. Mn Status: Offline Points: 554 |
+1 on the 74 mustang that was just listed.
1976 Ski Nautique 351 Escort
1984 Barefoot Nautique (Parting Out) |
burban65 ![]() Senior Member ![]() Joined: June-22-2008 Location: NW Indiana Status: Offline Points: 167 |
Check the for sale section here on CCF...........unless the 60's era is a must have I would say the 74 recently listed would be a good fit (looks very nice, great hours and price is fair).
Good luck! |
SRB
hi all, I am thinking about looking for a mid-60's Mustang. what are the red flag issues I should be on the lookout for? engine types, transmissions, hull issues...
also, what are the usual top and cruise speeds of these? thank you! |
