  New Posts New Posts RSS Feed - HELP
HELP
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Topic: HELP
    Posted: September-17-2020 at 11:32am
Typical- when you can't support your discussion always resort to name calling
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: September-17-2020 at 11:29am
The way the hoses are plummed on a PCM engine never let's the water drain out,there is always residual water there to lubricate the pump on startup.
Do you service your Sherwood pump as they recommend?
Looking at my GT-40 engine, there is a low spot in the raw water hose leading up to the RWP. It looks reasonable that there is some amount of residual water In the hose.  I pull pull my boat out of the water after every ski session as I trailer to/from the lake.  As such I’m glad to see that lubricating water is not far from the RWP on start-up.
As for servicing the Sherwood RWP....well on my old 1994 SNOB, I attempted to do a major rebuild on the pump, but crashed and burned on take-off.  At the time I didn’t have a hydraulic press required to properly disassemble and reassemble the pump and I ended up cracking the pump housing.  That cost me a $400 RWP.  I still have the rebuild kit and may attempt a rebuild on the new SNOB when engine hours indicate a major rebuild is due (based on Sherwood service hour recommendations).
As the impeller kit is only $25 and 10 minutes to install, this is a periodic service item I do every couple of years.  Overkill?  Perhaps.  I look at it as a modest insurance premium.
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: September-17-2020 at 11:24am
the latter it appears
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: September-17-2020 at 11:18am
A simple yes or no would suffice. Since your so into airplanes do you get to pick and choose on what and when you service them ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: September-17-2020 at 11:07am
Good plan Bailey
Gary enlighten us. you going to keep at it and remove all doubt?
River Rat to Mole
Baileys140 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Baileys140 Quote  Post ReplyReply Direct Link To This Post Posted: September-17-2020 at 10:20am
Originally posted by Baileys140 Baileys140 wrote:
got my new impeller on the way in the mail tpertoday that will be replaced sat. pertronix coil will be installed tonight. anti siphon valve coming ethier this weekend or next week. the date on my fuel filter water sep that was replaced last night was from 06. Im pretty scared to see what the impeller looks like and i imagine thats causing me probs on the water as it has probs not been replaced on a 25 yo boat (tears rolling) but saturday it will be done. Any body else got ideas for things that NEED to be replaced assuming they havent been in 25 years?
Besides the engine lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote Baileys140 Quote  Post ReplyReply Direct Link To This Post Posted: September-17-2020 at 10:19am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: September-17-2020 at 10:03am
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: September-17-2020 at 9:39am
Maybe some guys never have guests over. Seems that is when an old impeller shreds, or the cable pivot finally saws on half....
I ski, not just boat. I take others skiing and i'm not the exclusive driver, i let others take the helm.
 last thing i want to tell a driver is to watch that temp gauge. that implies its the most important thing. Especially when my daughter pilots im thankful she has since she was 15. She just would never have been a participating driver if i told her to watch the temp gauge every time i drop in.. just wouldn't. Then gottaski cant ski. not good.
 I expect a pilot's full focus on the safety of passengers, the craft, the shoreline, the rogue 60 mph pontoon boat that doesn't yield, or occasional lake lice that think its fun to mess up the 6am water.  whatever is left over, goes to my ski experience. I'm not giving that remaining faculty to a temperature gauge to save 30 dollars every other season.
Pete, i see your pump there,  shaft is supported on both ends, i suspect that keeps everything in place with high precision throughout its lifetime.. I've had the dual pumps on a Chrysler apart many times as well, same config.
On a old single circuit Sherwood, when the bearings get a little worn, the shaft torques over from belt tension a little, so on a LH engine this moves the impeller away from the wedge, creating low volume condition even with a fresh impeller, that can be maddening but more a nuisance because its mostly at idle until it gets worse, but very challenging to diagnose...
Conversly, i suspect, on a rh engine  the pump is flipped as you know and the impeller is now mashed toward the wedge more than usual, creating great flow at first,  but as it gets worse this decreases longevity as the vanes see very big deflections and can start to run out of room. So, in some contrast to your axiom,  that is one way i see impellers can shred early, without starting the boat without water applied.
Also, with the advent of lifts, some boat's pump configurations drain out and start dry every use. this happens
 even when dropped in the water, it starts dry, and eventually doesn't draw. Impellers wear early, when the temp spikes a few times and outing, its going to shred soon.
this happens to a ski buddy's centurion lapoint with a mercruiser 350 .
the pump drains out every time its lifted.
burns up  1-2  run-dry impellers a season with just daily use.
there is a simple solution of course, but some don't commit to modifying items asap
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: September-17-2020 at 6:18am
Those are 2 fairly ugly looking impellers too.
Ugly? If you say so, but here's the key:
I had no cooling problems
You obviously missed the point that your stories don't seem to agree from one post to the next when you get to telling the world how many years you go without doing things like checking impellers, points etc and you seem to forget about the years that your "trailer queen" or maybe "beam queen" never hit the water or got minimal use
You Pete are truly, the "king of preventive maintenance".
Hopefully every new owner that shows up here with questions follows your sterling example of how to take care of his boat Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: September-17-2020 at 6:07am
Originally posted by slmskrs slmskrs wrote:
I'd figure out the rotor issue (check with shaft play as mentioned).  See if there is any rubbing/wear indications inside the cap (was the cap seated properly?).
You said the lady you bought it from said 'it' was happening last year.  What is 'it'?  Rotors decimating themselves?  Or just occasional rough running/missing?  If the rotors have been trashing themselves, I would have wanted to get that resolved before buying the boat.  But that's water under the bridge.  Let's figure out the rotor/distributor issue first.
Umm..........I think he's beyond the rotor/distributor issue  Wink
update: I got a pertronix flame thrower dist and had it professionally installed. mine is 351w pcm 1995 all stock except for dist. Does this engine come equipped with a raw water pump from the factory and could not changing the impeller cause issues?
slmskrs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote slmskrs Quote  Post ReplyReply Direct Link To This Post Posted: September-16-2020 at 11:05pm
BTW, a VERY easy/quick way to determine if your impeller is working or not (I do this every time I replace it) is:
As soon as I start the engine, I immediately put my hand on the BACKSIDE of the RWP.  If it is not pumping water, it will get HOT very quickly due the impeller friction.  If water is flowing, it will stay cool.  Quickest way to check the pump/impeller.  Of course, if the impeller has disintegrated, that may not work unless there are still a couple of vanes turning against the housing.
Pix of the check engine light:
Gordon '97 Ski Nautique, GT40
Post Options Post Options   Thanks (0) Thanks(0)   Quote slmskrs Quote  Post ReplyReply Direct Link To This Post Posted: September-16-2020 at 10:56pm
Every time I try for 3 seasons on an impeller in CA I pay the price with impeller failure.  My local boating buddies follow the same advice.  I will stick with every two years in CA.
In my old '96 (purchased new), I ran the first impeller to about 450hrs before it disintegrated out in the California Delta at a slalom course.  Had a spare and was skiing again in 20 minutes.  Next one lasted another 400+hrs and it disintegrated at Santa Clara County Water Ski Club's site.  20 minutes later I was skiing again.
Is two years (or 200hrs which is what I do now) overkill?  Sure.  Was it smart to just run it until they died?  No!  It was stupid.  I could have clogged up channels in the engine with rubber, etc. or otherwise screwed up the engine.  While I always have the spare and the tools to do it in the boat, why do I want to risk overheating, not to mention disrupting a day on the boat?
I agree, cheap insurance.
However, we can talk RWPs and impellers all day, but without a working gauge, we don't know.  After oil pressure, temp gauge is the most critical and I would not run my engine without both working.
And since the RWP has nothing to do with an exploding rotor, the pump and impeller are 'possible' additional issues.
I'd then get the temp gauge fixed (I'm assuming the oil pressure gauge is working, if not, fix that first and then the temp gauge).  If none of your gauges are working, could be a ground or power issue in the dash, but I would not drive blind.
BTW, does your boat have the top center dash 'check engine' light?  If so (and those sensors are working), you do have back up temp and oil pressure notification/limp mode.  But get those gauges fixed!  :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: September-16-2020 at 9:31pm
Originally posted by GottaSki GottaSki wrote:
Glad were into boats and not airplanes
You airplane guys are always funny. I suppose you follow Sherwoods maintenance schedule to the letter?  LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: September-16-2020 at 9:27pm
Glad we're into boats and not airplanes
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-16-2020 at 7:58pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: September-16-2020 at 7:03pm
Pete, I believe your comment is true but I also believe it is true where you live.
The hotter states are much harder on impellers than the cooler states. We probably have 90 days over 90* and another 70 over 80*.  Equal to about 3 or 4 of your summers every year.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: September-16-2020 at 6:41pm
There are many who have fallen to the hype from the impeller manufaturers who love to sell impellers. Then there's me:
I've never blown one nor do I remove them for layup. This every 2 years is way overkill BS in my mind. These impellers (dual pocket) were still fine after 17 years
I changed them before I took the X55 to GL.
I feel those who have blown impellers have run them dry.
Pete Here's a quote from you in 2010 with the same picture. There's obviously some  BS being spread by you.
Get your sheet (as the Mexicans would say it) straight Wink
I've made several comments regarding the practice of frequent impeller change being unneeded. I'm on my 29th year of owning my 1964 with the 312. I just opened up the pump to take a look at the impellers after at least 25 years. I really wouldn't have bothered since I had no cooling problems but the bottoms of the hoses at the pump where getting real bad. (soft/gooey from the RV antifreeze) No broken blades, some wear on the tips, some "set" on the blades but no set at the cam from winter storage and some blade warpage.
The bottom line is running them dry is the killer and the marina's are spreading BS all over.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-16-2020 at 4:09pm
uncle-buck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote uncle-buck Quote  Post ReplyReply Direct Link To This Post Posted: September-16-2020 at 3:43pm
Ditto to what GottaSki wrote.
Replace that raw water pump impeller now and every year or two and save yourself lots of aggravation.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: September-16-2020 at 2:33pm
also, to add, just because its in tack doesnt mean its effective
the suction power comes from the vanes wanting to spring back to shape
once it takes on a set and hardens up, its effectiveness at pulling water goes way down.
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: September-16-2020 at 1:25pm
Any boat with a raw water pump should not be started without water, either from the lake or from a garden hose .  If the RWP is run dry the vanes in the pump can tear off and cause blockages in the coolant hoses.
I also change the impeller every 2 years.  For $35 and 30 minutes labor you can trust it to work every time.  Always carry a spare in the boat.   Call it insurance for great days on the water!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: September-16-2020 at 11:33am
Yes, your engine has a raw water pump. The RWP sucks up the lake water or the sea water for engine cooling. Inside of the RWP, there is a rubber impeller. If the impeller is old, cracked or worn, then the pump will not pump efficiently. The result is typically overheating issues. The RWP impeller should be inspected at least annually. In my boats, I change the impeller every two years — a bit of overkill, but it’s cheap insurance in my book.
And, no, the RWP won’t affect the distributor as the two systems are unrelated.  It’s like saying that a flat tire made the power windows stop working.  Unrelated. The RWP will certainly impact operating temperature of the engine, and high temps can and will impact other engine systems.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Baileys140 Quote  Post ReplyReply Direct Link To This Post Posted: September-15-2020 at 3:38pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: June-18-2020 at 2:20am
As your rotor came apart at high RPMs, you may have other distributor damage. As mentioned above, inspect your distributor for wobble, wear and the advance mechanism for proper function and lubrication.
Your boat may have a fuel filter / water separator. You may have to take the clamshell engine box off to access the fuel filter. Check on the port side of the engine compartment. It may be mounted at or below the floor level near the transmission. If your 1995 is similar to my 1994, it will look similar to a canister oil filter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Baileys140 Quote  Post ReplyReply Direct Link To This Post Posted: June-17-2020 at 3:08pm
do these engines have a fuel filter? my old 95 F150 had a fuel filter coming from the gas tank in the fuel line. i figure that would be another component just to replace. cheap easy fix. it looks like a canister with two stems coming off it
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-17-2020 at 2:44pm
Bailey,
It's pretty common to see corrosion inside the distributor. The most important clean up and lube is on the advance mechanism. Make sure it's moving freely. Don't worry about loose springs as they are loose normally when the RPM's are zero.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Baileys140 Quote  Post ReplyReply Direct Link To This Post Posted: June-17-2020 at 2:00pm
I will check distributor when i get home to check for loosness thanks guys. when i took the cap off of distributor internal compents looked pretty warn out and corroded. i guess timing springs could have rusted out causing engine to run bad
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-17-2020 at 1:55pm
Bailey,
As Tom mentioned above, have you had a chance to check if the distributor shaft is loose at the top from a bad bushing causing the rotor to run out?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Baileys140 Quote  Post ReplyReply Direct Link To This Post Posted: June-17-2020 at 1:22pm
i hooked my water hose up to the water intake and didnt look like i had any water leaks so i dont think its overheating but i definietly could be wrong
