  New Posts New Posts RSS Feed - SKi Tique Acme 1210
SKi Tique Acme 1210
Alex47 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex47 Quote  Post ReplyReply Direct Link To This Post Topic: SKi Tique Acme 1210
    Posted: June-24-2020 at 3:34pm
Great idea shimming out the prop guard with washers! I will see if that can offer enough clearance....
I don't think the prop guard is damaged or bend in any way that would reduce clearance.
Got Tiques View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Got Tiques Quote  Post ReplyReply Direct Link To This Post Posted: June-24-2020 at 11:19am
Had a similar issue with my 79 Ski. Cause of the interference was the PO backed the trailer into high ground and bent the prop guard upward and spread the bunks slightly apart. I removed the guard and straightened it on my press and pulled the bunks together to match the now correct guard. All back together and went from an interference to 2-1/2" prop clearance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morfoot Quote  Post ReplyReply Direct Link To This Post Posted: June-24-2020 at 8:33am
Stick with the new wheel as it will really wake up the boat. Add some washers to the guard attach points and shim out the trailer prop guard.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex47 Quote  Post ReplyReply Direct Link To This Post Posted: June-23-2020 at 3:13pm
Anyone have trouble replacing the original prop with the Acme 1210 and having trailer clearance issues? The boat shop said it wont fit due to the prop guard on the trailer. Its the original trailer...
I was really excited to try this new prop and the high praise its received from this site. I suppose I need to raise the bunks a few inches? Is the Acme 1210 a larger diameter than the original prop?
