Occasional missing at idle |
slmskrs
Gold Member Joined: January-03-2012 Location: SF bay area, CA Status: Offline Points: 522 |
Posted: June-24-2020 at 8:14pm |
I'm just finishing up the final items (carpet) of restoring my project boat ('97 SN 196). One issue I've had since I first got the engine running (after two years of sitting) is that I get an occasional miss at idle. At the beginning I replaced distributor cap and rotor, high tension lines, plugs, I also ran a ton of injector/fuel system cleaners (several different kinds).
When I put it in gear (both to back out of the dock and idling out to remove slack before pulling up a skier, it will sometimes miss. However, as soon as I give it any throttle it smooths out and runs great. Also, occasionally it won't miss at all. No clue what it might be but the only thing I haven't replaced are the injectors (that's been my suspicion for a while so thrown lots of injector cleaner in the tank. Any suggestions on something else to look at? I never did a compression check before getting the boat because the last time the previous owner had it at a mechanic, they did the test and only one cylinder was about 10% lower than the others (my '96 with 1,600hrs had the same thing, but no miss--and engine manual says within range). So I'm at a loss. Since it runs so well all the rest of the time (and sometimes when idling as well), I'm not horribly concerned. But I want to identify it and fix it. Thanks in advance, Gordon |
Gordon '97 Ski Nautique, GT40
