1992 ski nautique transmission |
slmskrs
Gold Member Joined: January-03-2012 Location: SF bay area, CA Status: Offline Points: 522 |
Posted: September-03-2020 at 2:31am |
Damper plate would only be a possible issue if it didn't turn in both forward and reverse. I had slipping in reverse, followed by slipping in forward in my '96. I pulled it and tore it part way apart. There is a rotating bell housing with a ring gear that turned in the housing. Long story short, I learned that the gear was press fit and was not supposed to turn inside the housing so it was shot. I didn't have all the tools to take it completely apart (presses, etc.), the parts (including new clutch plates since I had gone into it), was somewhere in the $600-700 (or more) range, and I had no idea whether I could get it back together again correctly (especially without presses). It wasn't worth it to try, have no warranty, and possibly screw it up, so I opted for the 80A from SKIDIM. A few things about the SKIDIM 80A. It comes as a 'kit' with the tranny, a new damper plate, and a 12" tranny cooler and long hoses!! The tranny housing in the back is higher than the 40A (looks like the housing is also used for V-trannies) and I was afraid it might not fit where I could get my floor board back down. But it did fit fine (you have the same hull as my '96). Even though the housing is aluminum, the sucker is heavy; you need two people to put it back in (my back is still feeling it years later). I was so pleased with how it operated as well as that 12" cooler, when I got my '97 project boat, one of the first things I did (original tranny) was to put a new 12" cooler in (the 12" is around $200 if you buy it separately, so the kit is a little more reasonable since you get the cooler and the damper plate). My damper plate had probably 1300hrs on it, but other than a little rust, was perfectly fine (although of course I replaced it with the included new plate). Also on costs, it would have been 1200-1400 to have mine repaired/rebuilt by someone else, and a rebuilt with maybe a 30 day warranty just wasn't worth it. I'm glad I did it. Of course, I hope my tranny in the '97 holds up a long time (hence the 12" cooler and I now have an electric pump that empties the fluid in about a minute so I"m now changing the tranny fluid every 50 hours with the engine oil change--easier than the oil change). If/when the current tranny goes, I'll most probably opt for a new 80A.
Gordon '97 Ski Nautique, GT40
slmskrs
Did you turn it with the prop shaft coupler/prop attached to the tranny, or did you pull the bolts out of the coupler and then turn the coupler on the tranny? Just want to make sure / confirm the clunks, etc. are coming from the tranny (I assume so). When it goes into reverse, is this in the water with a load on the prop? Just wondering whether it is slipping in reverse or it's fully engaged. Are there any noises when it's turning with the engine (as opposed to when you are turning it by hand)? If so, same noises in forward and reverse? If you have disconnected the prop coupler so the tranny would spin freely and you run the engine, with no load on it, does it turn at all in forward? Unfortunately, all of these things point to internal issues... :( I'll post separately on my experience in replacing a 40a with an 80a in a '96 SN (should be the same hull as you).
bobbysworld
Newbie Joined: September-01-2020 Location: Austin, Texas Status: Offline Points: 4 |
Correct, no movement.
Could the damper plate be a cause, or would that result in neither forward or reverse. I'm kind of to the point where I need to know if sending it to a mechanic and then off to get rebuilt would be reasonable or from what I have read getting a newer 80a installed. Any help as far as pricing, locations and opinions are greatly appreciated! |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11118 |
Roll, thud, clunk is never really a good thing.
Combine that with the shifter working like it should by hand and you're looking at internal transmission issues. Might be a silly question, but when it's in forward and you look at the shaft and the coupling at the back of the transmission they're not moving at all ?
bobbysworld
The shift cable was taken off by said mechanic. Also forgot to mention that i previously tightened the packing nut because it was a steady stream coming in to the boat. got it to about 5-10 drops a minute. While rolling the prop shaft behind motor i can feel a roll then a thud/clunk when done turning not a smooth turn by any means.
SNobsessed
As a test, you could try to unhook the shift cable at the transmission & operate the valve lever by hand. It could be your shifter/cable connection.
bobbysworld
I have a 1992 ski nautique which has never had problems until I purchased from friend. Third time cruising the lake all day. go to put in gear and prop won't engage. Reverse does engage the prop, but nothing while in forward. Never felt or heard any slipping. It was looked at by a mobile mechanic and thinks its transmission related. (40a 1.23.1) Im looking for any guidance that can be given thanks in advance.
