  New Posts New Posts RSS Feed - Winterize pump AF no plugs removed
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Topic: Winterize pump AF no plugs removed
    Posted: September-19-2020 at 7:21am
Well the good news is that you'll sleep on those cold nights.
What kind of antifreeze was this that you tested at -12 degrees C?
RV / marine antifreeze or automotive type stuff?
If it's the RV/marine stuff, the freeze point doesn't tell you much at all, you're more worried about the burst point.
But the real point is that you weren't comfortable and now you are with your same dealer that did it for years with a warranty to go along with it..Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-19-2020 at 5:57am
Originally posted by rwittmer rwittmer wrote:
I checked the AF that came out of the manifolds (drain plugs) and tested at -12 degrees C.
That's only 10 degrees F. I'm glad you went and got the winterizing done correctly. Come spring your may have been very disappointed with that pump through method.
rwittmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rwittmer Quote  Post ReplyReply Direct Link To This Post Posted: September-18-2020 at 9:12pm
I checked the AF that came out of the manifolds (drain plugs) and tested at -12 degrees C. So I took advice from all here and decided to go to my servicing dealer. Well re-winterized it as per CC dealer and now have peace of mind. The dealer also made me a fair price and will be charging me $450 with oil change in the future.
Thanks to all for the logical advice.
Rene Wittmer
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: September-09-2020 at 5:56pm
Well the thread is aleady jaxed, so here is my rant-
Both myself & neighbor had bad gas this summer.  somehow ended up with so much water in it engine (lawnmowers) wouldn't run.  I only use non-eth for small engines.  I am wondering if the non-eth pump is always non- eth.
My neighbor got stung as his rider was under warranty & he just had them come & pick it up.  They charged him about $500 for the fuel system overhaul.
Never had problems until this summer, just sayin'
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: September-09-2020 at 8:27am
Originally posted by Riley Riley wrote:
How do you determine quality of fuel?   Could your poor quality fuel be the result of not using stabilizer? Stabilizer doesn't help when you add it in May after sitting all winter...
If you’re having consistent fuel trouble then consider the possibility that the source may be the problem. Maybe it’s low quality from the outset and maybe it’s been sitting in their storage tanks too long? Establishing a trusted source of quality fuel may take some time but a little common sense may point you in the right direction.
Oh you mean stabilizer only works on fuel that hasn’t gone bad yet? Who knew?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Riley Quote  Post ReplyReply Direct Link To This Post Posted: September-09-2020 at 8:08am
Either way I’d be sure that the fuel was of high quality before storing and I’d top it off with fresh in the spring. Fuel quality/freshness has made a much bigger difference than anything else in my boats- with what I now assume was lower quality (lower cost) fuel, stabilizer never helped. I couldn’t get the boats to start if they had sat for 2 weeks (without a shot of fresh down the throat). With what I believe to be better fuel, my boats will start on 2yr old fuel. Both are/were e10.
My 2 cents.
I don't see what the big deal is about pulling 4 or 5 plugs and a couple of hoses to drain the water.
Nautiquehunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nautiquehunter Quote  Post ReplyReply Direct Link To This Post Posted: September-09-2020 at 7:15am
Every year these posts come up on how you can save time not having to pull 5 drain plugs . It takes more time to change the oil . I have been doing my boats the same way for better than 30 years . Drain it then fill it at the raw water pump hose going to the thermostat until it comes out the exhaust . Only difference is now that I live in the south I only do 33% antifreeze instead of 50%. The real time is spent on cleaning,waxing and polishing all my boats are put away ready to start the new year.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-09-2020 at 7:08am
I did check and there is NO warranty against frost damage.
Hmm, This sure tells all about the pump through process!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-08-2020 at 7:34pm
Kind of a blanket statement- there are approximately 20 different blends of gasoline through out the country-.
I remember one year after Tim was at the Green Lake reunion he thought the midwest gas was bad because of the color. It was too orange/yellow for him. Big smile LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: September-08-2020 at 7:24pm
Kind of a blanket statement- there are approximately 20 different blends of gasoline through out the country-what works somewhere might not in others. Right now I'm using 2 year old Illinois fuel in 3 different tractors. I have had 3 month old Florida gas go bad eating a tank liner. Because of that I drain every thing except the tractors now.
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: September-08-2020 at 5:32pm
Here here Tim
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: September-08-2020 at 5:31pm
One size fits all doesn’t work well on fuel tank storage either.
I have seen lots of bad things happen when people run their tanks very low... they pick up junk and contaminate their entire fuel system. With that caution in mind, I would:
If I had a metal fuel tank I would keep it relatively full to prevent moisture from corroding it over the winter.
If I had a plastic tank I would let jt get fairly empty before storing for the winter.
My 2 cents.
burban65 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote burban65 Quote  Post ReplyReply Direct Link To This Post Posted: September-08-2020 at 5:13pm
Winterization side note:  I just talked to a very reputable Nautique dealer a few weeks ago and they said they changed their approach on winterization awhile ago and are not filling and treating the gas tanks anymore rather they are leaving tanks at a relatively low level and treating the gas that is in the tank before putting away.  Then come the start of the season they are advising their customers to put in some small amount of fresh gas and having them run the majority of the fuel out before adding more "new" gas.
Just passing on what information was relayed to me by a very reputable dealer.
SRB
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: September-08-2020 at 3:21pm
It seems people are still confused about what the thermostat does- it should be noted that it controls water flow OUT of the engine (not IN). It can also be highly dynamic- just getting the engine “up to temp” doesn’t mean that it opened at all- let alone that it opened long enough for any presumed mixture ratio of AF to have backfilled in its place. The path out the exhaust manifolds is different and while it’s interesting to note the freeze protection offered by what came out the back, it doesn’t mean that’s what you’ve got inside the block.
Ken’s comfort level comment is spot on. I know what I’d be doing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: September-08-2020 at 2:33pm
I'm sure the guy watched the temp gauge to ensure it was up to temp.
Being that you're pumping hot recirculated water back in it doesn't take it long to get warm. The 10 minutes he ran would be more than enough time to get the motor up to temp to open the T-stat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: September-08-2020 at 11:46am
I realize you stated that the engine was run for a few minutes first.  Keep in mind that if the engine was not at full operating temperature, then the thermostat was likely still closed and little or no antifreeze found its way into the engine block. In many marine applications, the thermostat is designed to let water bypass the thermostat (while thermostat is still closed) and go directly to the exhaust manifolds.  As such you may have no A/F in the engine block.  I would opt to pull the drain plugs and drain all fluid from the engine.  If you are still wanting A/F in a cold, drained block, you can add It directly into thermostat housing or into the intake manifold through temp sender port.
Most of the “environmentally friendly” A/F that I’ve seen doesn’t have anti corrosion additives.  Yes, there are some that do have anti rust additives, but I prefer the “dry block” lay-up procedure as I just don’t see the value in the marine A/F.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: September-07-2020 at 8:06pm
Just playing the devils advocate as there is more than one way to do and do it right.
  With the accessory’s of of the newer boats with showers, heaters, ballast tanks, ballast pumps the “OLD” just drain and leave dry may not be the easiest way anymore.
  I find so much easier and complete to just to run it and pump it through out the whole system, no blowing this or that, just run it and pump it... and DONE
 As for the cost, if 6 gallons of $3 antifreeze is a budget breaker maybe you should take up chess or checkers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-07-2020 at 7:43pm
Originally posted by gun-driver gun-driver wrote:
Originally posted by SNobsessed SNobsessed wrote:
You can drain & leave dry for $0.
How do you know the heater core and/or the shower is dry??? Also leaving it dry is an invite for rust/corrosion of the small passages.
Paul,
The drain only was and still is a popular option. It's been done since true antfreeze wasn't even around. I have never had a problem with rust/corrosion nor have I ever heard of a problem. As an example, my 54 has never seen a drop of antifreeze and the neighbors 49 Chris that I take care of has never seen any ether. Also, the engines I do add antifreeze to, I never even try to fill up the block. Maybe a gal. at most to get the low spots. Again, rust has never been an issue. I know of 2 marinas in my area that adding antifreeze for winterizing is an option after draining.
Regarding the heater or shower, the best way is to disconnect and blow them out
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: September-07-2020 at 7:39pm
There must be 50 ways to drain your water, I think that was an old Simon and Garfunkel tune Wink About 1975 or so
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: September-07-2020 at 7:26pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: September-07-2020 at 6:23pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: September-07-2020 at 5:36pm
Rene can you do us a favor?
When you drain the antifreeze out of the motor Can you save enough to get a test on it, that way we will know(for the future) and you will know if he did a good enough of a job or not to get it through a Canadian winter. And if it tests good enough $150 sounds better than the $582 from the dealer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rwittmer Quote  Post ReplyReply Direct Link To This Post Posted: September-07-2020 at 4:58pm
Keno,
You're right. I don't really feel comfortable, so I will go back next weekend and drain as you suggested. I did check and there is NO warranty against frost damage. My dealer will guarantee the job and will take responsibility for any damages. The dealer charges me $582 cdn which includes winterize of engine, fuel stabilizer and engine oil change. Since I really enjoy my Nautique I will go back to a full servicing dealer.
Thanks for your insight.
Rene Wittmer
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: September-07-2020 at 2:54pm
So Rene...........it looks like your boat has been winterized the same way by the dealer over the years and nothing has cracked yet
Now you have a new guy doing it the same way.
You really don't know what's been used for antifreeze though. I'd ask him a few more questions.
You must be in the Canadian Banana Belt if protection down to minus 30 degrees C (minus 22 degrees F) is always gonna keep you protected Wink
I guess you'll have to decide if you're comfortable
If you're not, then drain the engine,exhaust manifolds, trans cooler and whatever heaters you have..
If you're comfortable, you're all set
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-07-2020 at 12:05pm
Paul,
I will tilt a boat bow low whenever I can to get that starboard side block drain as low as possible. You are correct that there are no gaurantees that all the water is out but certainly I feel better than just the pump through.
Regarding heaters and showers, the best way is to blow them out unless you can confirm removal of hoses will create a low point for draining.
Keeep in mind that for draining, the T stat doesn't come to play since it's at the high point in the system.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: September-07-2020 at 11:44am
How can you have a good argument about antifreeze without knowing that Wink
Good point Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: September-07-2020 at 11:23am
All this discussion and there's been no question like..........."what kind of antifreeze does the mobile guy use?"
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: September-07-2020 at 11:00am
Pete how are you sure you get all the water out when you just drain? Is the motor level, is it leaning to one side, do you raise and lower the nose, how do you know the heater was empty  and got antifreeze into it?
  There’s more than one way to skin a cat Pete, and I believe that running the motor to reach thermostat open temp is better than just draining and pouring especially if you have a heater and or shower like the poster and I do.
  I do agree that it’s better to drain then run but again he used plenty of antifreeze.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-07-2020 at 10:42am
It doesn't matter how many galons you use,it's how well did the antifreeze mix with the water? Are there any pockets in the cooling that didn't get the velocity to mix both together?
Rene,
Again, did the cost include a gaurentee in writing? The guy isn't going to tell you how many blocks he's busted! As mentioned, why doesn't he take the time to do the winterizing the safe way and drain the block first?
Post Options Post Options   Thanks (0) Thanks(0)   Quote rwittmer Quote  Post ReplyReply Direct Link To This Post Posted: September-07-2020 at 10:10am
@gun-driver, I just spoke with my mobile mechanic and he told me that he has been winterizing boats for years and he never removes any plugs at all. The AF he brings to his shop and reuses it until he sees that the mixture is no longer strong enough for the cold weather. The method used is safe when you have "heaters" like my CC has.
Rene Wittmer
