Wiring diagram |
AlfaDon
Senior Member Joined: September-18-2011 Location: San Leandro, Ca Status: Offline Points: 407 |
Posted: September-10-2020 at 9:00pm |
Correction. The odd sequence wires weren’t grounded at all. Problem solved
AlfaDon
Odd sequence meaning I push one breaker and a non corresponding indicator lights. BTW I’ve reconfigured the ground wires for the indicators and they seem to be correct. Now to look for open connections in the wiring
Odd sequences meaning bilge pump or lights?
AlfaDon
Does anyone have the dash wiring diagram for a 96? Mine is a 176 but I’d imagine a 196 would be the same. I’ve found a couple from earlier years in the reference section but I’d really like to identify the wire color codes.
I’m having trouble with the indicator lights next to the breakers lighting at odd sequences and I think it might be because they’re not all grounded at the same point. Thanks Don |
