  New Posts New Posts RSS Feed - 1978 Fish Nautique
1978 Fish Nautique
leetudor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote leetudor Quote  Post ReplyReply Direct Link To This Post Topic: 1978 Fish Nautique
    Posted: December-15-2020 at 8:22am
Hope to have it running this week!
Post Options Post Options   Thanks (0) Thanks(0)   Quote leetudor Quote  Post ReplyReply Direct Link To This Post Posted: November-03-2020 at 10:03pm
So I installed the standoff transmission mounted shift cable bracket and routed the cable the new way.  Well have to order a new cable 8 feet shorter now.  The way things are going, I am going to install the cable before I change the throw on the handle side as it could be wrong.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ultrarunner Quote  Post ReplyReply Direct Link To This Post Posted: November-02-2020 at 9:55pm
Originally posted by SNobsessed SNobsessed wrote:
It's amazing it stayed on at all.
I’ll say. Had to been a good vibration. All held together by that cotter pin. Loose a prop at sea and someone stocked the wrong size spare, ok, I get that. But on purpose for daily use??? That’s some thinking there.
In all fairness, it does case me to pause and think a bit at what I did to keep my old cars running as a kid with little or no money;-)
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: November-02-2020 at 6:36pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ultrarunner Quote  Post ReplyReply Direct Link To This Post Posted: November-02-2020 at 11:21am
WOW, that's not something you see everyday!
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: November-02-2020 at 11:02am
Ugh.
Amazing the effort people make to do things wrong and be proud of it afterward
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote leetudor Quote  Post ReplyReply Direct Link To This Post Posted: November-02-2020 at 10:51am
Well in this politically correct world, this thing was rigged.  Prop must be 1 1/4" hub, as a 1 1/8" prop I had sitting around fits the shaft correctly.  Someone had to make a special keyway to match the shaft and the prop.  They used Teflon tape to take up some of the slack.
Post Options Post Options   Thanks (0) Thanks(0)   Quote leetudor Quote  Post ReplyReply Direct Link To This Post Posted: November-01-2020 at 8:06pm
Lee,
It looks like the PO used a prop with it's bore bigger than the shaft? Is the prop at least seated on the shaft taper or loose? How close is the prop hub to the strut?
I am going to pull the prop tomorrow and see what is up.  When I first looked I just noticed how close it was to the strut and not all of the spacers.  The prop is maybe a sheet of paper from the strut.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: November-01-2020 at 7:51pm
Lee,
Post Options Post Options   Thanks (0) Thanks(0)   Quote leetudor Quote  Post ReplyReply Direct Link To This Post Posted: November-01-2020 at 7:39pm
How does this prop nut hot garbage work out?  I bet this is not factory setup either.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-23-2020 at 1:47pm
Originally posted by fanofccfan fanofccfan wrote:
My bad....did not read the entire thread.
Bill,
I've done it may times too. Then the only problem is, it gives Ken another excuse to come after me with his criticism!
You bet it does. You just ask for it.
By the way, you misspelled "many"   Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-23-2020 at 1:33pm
Bill,
Post Options Post Options   Thanks (0) Thanks(0)   Quote fanofccfan Quote  Post ReplyReply Direct Link To This Post Posted: October-23-2020 at 12:32pm
Have you tried following the battery cables from the starter to wherever they may go?
Yes, Like I said above they go into the livewell and I do not want to put them back into that compartment.
Post Options Post Options   Thanks (0) Thanks(0)   Quote leetudor Quote  Post ReplyReply Direct Link To This Post Posted: October-23-2020 at 10:56am
Here's a link to a bracket kit, maybe you have some of the parts but not all from the sound of it
Here's a picture that shows how it mounts
SO the stand off L bracket came in today.  I am going to mount it and look into changing the throw action of the handle this weekend.  I will for sure have to get a much shorter cable.
Post Options Post Options   Thanks (0) Thanks(0)   Quote leetudor Quote  Post ReplyReply Direct Link To This Post Posted: October-22-2020 at 10:17am
Originally posted by rebel skier rebel skier wrote:
look like here:
I thought about that area, will need to add a door to my floor panel for easier access.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rebel skier Quote  Post ReplyReply Direct Link To This Post Posted: October-22-2020 at 9:59am
I wouldn't be surprised if that live well batter was set up to be a house battery versus a starting battery.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rebel skier Quote  Post ReplyReply Direct Link To This Post Posted: October-22-2020 at 9:58am
It might be worth tryin to grab the pics in this old for sale add too:
The problem is if you create an account with pop yachts they will spam you for a good while.
Post Options Post Options   Thanks (0) Thanks(0)   Quote leetudor Quote  Post ReplyReply Direct Link To This Post Posted: October-22-2020 at 9:57am
Post Options Post Options   Thanks (0) Thanks(0)   Quote rebel skier Quote  Post ReplyReply Direct Link To This Post Posted: October-22-2020 at 9:54am
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-22-2020 at 8:54am
Also where does the battery go?  Mine was mounted in the livewell and I want that for storage not a battery.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fanofccfan Quote  Post ReplyReply Direct Link To This Post Posted: October-22-2020 at 8:38am
Post Options Post Options   Thanks (0) Thanks(0)   Quote leetudor Quote  Post ReplyReply Direct Link To This Post Posted: October-21-2020 at 1:05pm
Does anyone know the battery location?
Post Options Post Options   Thanks (0) Thanks(0)   Quote leetudor Quote  Post ReplyReply Direct Link To This Post Posted: October-20-2020 at 10:08pm
This is what it looks like.
Post Options Post Options   Thanks (0) Thanks(0)   Quote leetudor Quote  Post ReplyReply Direct Link To This Post Posted: October-20-2020 at 10:03pm
Thanks, I will look better at it in the morning.  If I go that route, I will need a new cable about 5 foot shorter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: October-20-2020 at 9:40pm
If it's like this they used those controls in a lot of boats. It will just need the cable attachment to the throttle bellcrank and it's clamp moved to the opposite side of the control....
Something like this-
Post Options Post Options   Thanks (0) Thanks(0)   Quote leetudor Quote  Post ReplyReply Direct Link To This Post Posted: October-20-2020 at 8:56pm
Thanks.  I will look at mine closer and see if it is the same.  Top side looks different but bottom side might be the same.  Might take a brain surgeon to sypher it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-20-2020 at 8:10pm
I have an Ole School dual lever shifter.
Here's a manual for a dual lever shifter that may or may not be the same as yours since you didn't say what yours is Wink
But ..........if you read it you can see that the shifter can be setup to push or pull with a little disassembly to get at things, then when you move the lever forward, the boat will go forward.
Whatever make and model you have, it should have that capability.
Once again.......good luck
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-20-2020 at 7:27pm
Well, I'm no help then Wink
Good luck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote leetudor Quote  Post ReplyReply Direct Link To This Post Posted: October-20-2020 at 7:21pm
If I mount mine like that, the directions will be opposite.   Forward would be reverse.
Click on the link below for a Morse throttle/shift control manual
It's for an MV-2, you could have an earlier MV-1 but the directions for changing the shifter action are basically the same thing.
If you have some other control, then this is no help Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-20-2020 at 6:20pm
