  New Posts New Posts RSS Feed - Trailer seals
Trailer seals
Mpost View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mpost Quote  Post ReplyReply Direct Link To This Post Topic: Trailer seals
    Posted: March-06-2021 at 8:57am
Double check your OD. also. That 10-10 seal does not seem to come in any of the bearing kits. Had to order them seperatly.
84 SN Sold   98 SN    Lund Pro V   1975 Alumacraft
Kat Daddy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kat Daddy Quote  Post ReplyReply Direct Link To This Post Posted: March-05-2021 at 8:28pm
That measurement sounds about right, bought a digtal thing from harbor freight and was 2.13...close enough.
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: March-05-2021 at 9:38am
That should work. Whatever comes in the standard 5200lb(bearing/hub) kit is what you need.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mpost Quote  Post ReplyReply Direct Link To This Post Posted: March-05-2021 at 8:31am
Originally posted by 67 ski nat 67 ski nat wrote:
You might be able to use micrometer and measure innner and outer. That should narrow down
Thats what I had to do with my 98 SN trailer. This is what I ordered from E-trailer.
10-10 Grease or Oil Double-Lip Seals
I.D.
O.D.
Use With:
2.1253.376E-Z Lube and Oil 5,200, 6,000 and 7,000 LB Axles
Post Options Post Options   Thanks (0) Thanks(0)   Quote 67 ski nat Quote  Post ReplyReply Direct Link To This Post Posted: March-05-2021 at 3:53am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kat Daddy Quote  Post ReplyReply Direct Link To This Post Posted: March-04-2021 at 9:27pm
Does anyone know an inner wheel seal # for the 6 lug bfn trailers? It has the ez lube axle and etrailer cant cross reference it.
