  New Posts New Posts RSS Feed - Throttle controller
Throttle controller
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Topic: Throttle controller
    Posted: April-29-2021 at 6:41am
SF4
You need to quit posting in this thread and go to your other thread cause it's getting too confusing.Wink
Keep it all in one spot
Slalom fan 4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slalom fan 4 Quote  Post ReplyReply Direct Link To This Post Posted: April-28-2021 at 8:09pm
I think it jas nothing to do with the trans end of the deal. I'll just have to take the controller out and see if I can figure it out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slalom fan 4 Quote  Post ReplyReply Direct Link To This Post Posted: April-28-2021 at 8:04pm
It does it even with cable off of trans. Probably from moving lever too much when it was stiff and now that I remedied that it's left over wear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-28-2021 at 7:57pm
Originally posted by Slalom fan 4 Slalom fan 4 wrote:
No and no.
Rodney,
I'm just trying to figure out why you're up at the helm when the change made creating the problem was at the trans.
One of the suggestions was to remove the cable at the trans shift lever and manually move the lever to see if it was binding. Did you do that?
With the cable disconnected at the trans, does it move smoothly?
Did you ever look at different cable routing to minimize cable bending?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slalom fan 4 Quote  Post ReplyReply Direct Link To This Post Posted: April-28-2021 at 7:31pm
No and no.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-28-2021 at 7:13pm
Rodney,
When the new trans was installed, were new cables installed? If not and the old were used, were they disconnected at the helm?
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: April-28-2021 at 5:38pm
I posted this in your other throttle controller thread too
Don't feel like the Lone Ranger as far as the picture posting
If it didn't scrape before, it shouldn't be scraping now, I think you have the "rough adjustment" done and if you play with the barrel connector adjustment for a fine adjustment, you'll make everything smooth without getting a new controller........unless you have this wild urge to get a new one.Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slalom fan 4 Quote  Post ReplyReply Direct Link To This Post Posted: April-28-2021 at 1:29pm
So I've adjusted the shift cable on the new transmission and the lever has lost most of its stiffness but now there is a scraping sound and grabbing during forward travel inside the controller. I pulled it out and disconnected cables and it's smooth. I'm thinking it's got gremlins in it.
