1993 SN Prop Options for Go Fast? |
![]() ![]() ![]() ![]() ![]() Posted: May-21-2021 at 5:13pm |
From what I have learned here, those last few MPH take exponentially more HP.
Fred,
There's still a chance for improvement but that really depends on what prop is on the boat now. Do you know what it is?
fanofccfan ![]() Platinum Member ![]() ![]() Joined: December-13-2009 Location: North Bend NE Status: Offline Points: 1796 |
KENO ![]() Grand Poobah ![]() Joined: June-06-2004 Location: United States Status: Offline Points: 11184 |
Sometimes Fred the short simple answer is just so right ![]() |
TRBenj ![]() Grand Poobah ![]() ![]() Joined: June-29-2005 Location: NWCT Status: Offline Points: 21197 |
No
Jonny Quest ![]() Grand Poobah ![]() ![]() Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 3009 |
Acme 442 would likely be the “stock” recommendation. Acme 668 may work for speed and no skier — 668 is very close to the 442 but with a bit more cup. But as Pete asked above, we need to know a bit more:
- Elevation (St. Paul is about 1,000 feet) - Engine particulars - Wide Open Throttle (WOT) spec for your engine That will help us dial things in a bit more… JQ |
Fred,
What prop is on the boat now? Also, what's the WOT RPM?
FredWSauer ![]() Senior Member ![]() ![]() Joined: August-28-2015 Location: St. Paul, MN Status: Offline Points: 156 |
My first boat 24+ years ago was an Arriva 2001 with a 150hp outboard. I used two props. One I recall was a 16 pitch for water skiing good hole shot and a top speed of 38 and the other was a 21 pitch cupped prop for going fast and having fun.
Would that work for a 1993 SN if I was day boating with the wife or on the annual poker run to have an alternate prop I use for a bit more speed? Not a good idea or? |
- FWS
1993 Ski Nautique 1978 Glastron T-160 1994 Weeres Pontoon - Wife's Boat |
