  New Posts New Posts RSS Feed - Water inlet
Water inlet
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Topic: Water inlet
    Posted: May-24-2021 at 5:58am
Bracken,
No check valve. The flexible impeller pumps in our boats are self priming. Sounds like you are sucking some air via leaks. Double check all your hose connections.
Netcott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Netcott Quote  Post ReplyReply Direct Link To This Post Posted: May-23-2021 at 10:23pm
I bought a 73 mustang 16 that had been taken apart for a restore and when I bought it, it was a box of parts. After restoring it over the winter I finally took it out today for a leak test. I initially had an overheating problem that I resolved after pulling the hose past the pre water pump and sucking on it until I got water.
After that, the hose flowed water and the temps went down. Pre pump has new impeller and I am certain I have the in and out correct. As far as the rest of the cooling I assembled it based on pictures so something might not be correct but I'm pretty sure it is.
My question is this, is the inlet supposed to have a check valve to keeps it primed? It seemed like it struggled to prime but was good after it did.
