  New Posts New Posts RSS Feed - Engine Rotation
Engine Rotation
Post Options Post Options   Thanks (0) Thanks(0)   Quote 67 ski nat Quote  Post ReplyReply Direct Link To This Post Topic: Engine Rotation
    Posted: June-03-2021 at 8:47am
This is A very interesting topic.
I’m still learning about these boats too
Had no idea the LH would be an issue
On first glance appears you found a great 454 project
But if TRB is concerned, I’m too
Post Options Post Options   Thanks (1) Thanks(1)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: June-02-2021 at 1:37pm
I had a ‘87 barefoot Nautique with a lefty in it… the handling/lean wasn’t as problematic as some of the smaller/older/flat bottom LH-converted cc’s I’ve driven. But it still wasn’t good. I certainly wouldn’t advocate a lefty prop in one of those boats.
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: June-02-2021 at 12:58pm
ok If you are new to these point us to some pictures maybe we can identify issues for you
If you have 'the knack' at all should be fun project, inquire here anytime
River Rat to Mole
2000SS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2000SS Quote  Post ReplyReply Direct Link To This Post Posted: June-02-2021 at 12:36pm
Originally posted by GottaSki GottaSki wrote:
You intend to test the boat on the water, yes? recommended
Some SN & BF boats came with a left hand engine, and its not confirmed there is anything speshul about those hulls , so its not all that concerning at first
Anything else modified?
Thank you.  It has not run in over ten years, so I would have some associated risk with the purchase.  The owner has passed away, and the seller does not have any mechanical history.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: June-02-2021 at 12:29pm
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2000SS Quote  Post ReplyReply Direct Link To This Post Posted: June-02-2021 at 9:28am
I am looking at a 90 Barefoot, and the previous owner replaced the engine with a LH 454.  Any concerns I should have pursuing the purchase?
