  New Posts New Posts RSS Feed - Water Pump Question
Water Pump Question
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Topic: Water Pump Question
    Posted: July-04-2021 at 8:10am
Rich,
I went back into your previous posts and did find that your 65 did have a problem with rubber impeller pieces back awhile. It may be worth disconnecting every hose and then connecting up the garden hose to each to see if you can flush anything out. I'd also open up the T stat housing and drain plugs and run some water through the engine as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-03-2021 at 9:02pm
Rich,
The poly should have water distribution tubes internal of the exhaust manifolds. These are used to ensure water is distributed evenly in the manifold by eliminating any air pockets. They will look like a length of copper pipe. Maybe one is plugged up? When your uncle did the impellers, were thay busted up? I ask since the pieces of impeller can travel plugging some pasages.
65Cuda View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 65Cuda Quote  Post ReplyReply Direct Link To This Post Posted: July-03-2021 at 7:47pm
I have a 65 Cuda with a 318 Poly.  my uncle replaced the original water pump and ever since the high/front side of the exhaust manifold is overheating.  the water pump is a Sherwood dual pump.  would anyone have experience on what would be causing the manifolds to heat up?  rest of the engine is cooling fine, the exhaust manifold elbows are cool to the touch.  I am thinking to pull the water pump apart and check out the impellers.  Also thinking the water pump might not be drawing enough.  Any help is much appreciated.
