holman moody 302 |
KENO ![]() Grand Poobah ![]() Joined: June-06-2004 Location: United States Status: Offline Points: 11236 |
![]() ![]() ![]() ![]() ![]() Posted: July-29-2021 at 5:02pm |
you'll need a RH crankshaft because the normal rotation crankshaft has knurling/wick/helix lines going the other direction at the rear main seal and you'll have an oil leak. Or......you get the lines machined out or a speedi sleeve installed and hope the smooth 2 pc rear main seal seal works. Gary S can tell you what he went through and did for a non leaking rear main seal or here's a link to an old thread where he mentions it. And only a RH distributor gear for your present distributor
pjsmoreno ![]() Senior Member ![]() Joined: April-25-2016 Location: Liberty, Mo Status: Offline Points: 200 |
Wow like that dark blue on that engine! Great choice.....
93/70 ccpb ![]() Senior Member ![]() ![]() Joined: March-05-2006 Location: United States Status: Offline Points: 448 |
if i change from left hand to right hand rotation what do i need,,(right hand dist ,right hand cam, right hand starter)anything else?
what you dont want to hear from jbear and bill.you cant get in the boat till you get your minute,and they throw you back in water!
MourningWood ![]() Gold Member ![]() Joined: June-13-2014 Location: NorCal Status: Offline Points: 920 |
I run a '69 Mustang in a vintage race group. For the Fords of the era, Duple-Color DE1606 seems to be the engine paint of choice.
'I measured twice, cut three times, and it's still too short!" |
67 ski nat ![]() Platinum Member ![]() Joined: July-19-2018 Location: Santa rosa Status: Offline Points: 1199 |
Gary beautiful engine very nice detail
Do people on dock comment when you lift doghouse |
ok thanks all i think ill go with dark blue,is going to be put on backburner till this winter.
Jonny Quest ![]() Grand Poobah ![]() ![]() Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 3024 |
I do like that color, Gary. Better than the the lighter Ford “blue”.
Mine had a bunch of colors on it- it was hard to decipher. There was no light blue but it did have a dark blue and someone thought black looked good on parts of it. I went with the dark because I liked it.
TRBenj ![]() Grand Poobah ![]() ![]() Joined: June-29-2005 Location: NWCT Status: Offline Points: 21207 |
I want to say “old Ford blue” might be close, I know reid will remember. Believe the interceptors of that vintage used “Ford dark blue”.
tim i think its a 68 has lighter blue not the real dark blue
What year? They differed
color code for holman moody blue?
