Bilge blower location 83 ski Nautique 2001 |
GeoB ![]() Newbie ![]() Joined: July-12-2021 Location: Connecticutt Status: Offline Points: 36 |
![]() ![]() ![]() ![]() ![]() Posted: August-02-2021 at 9:24pm |
Thanx for this post.
I just purchased my first boat, 1985 SN 2001. Dead blower motor. Turned out it is that switch/breaker. I ordered one and it has slide on connections. I’m thinking that I want the screw connections as I have to avoid vibration issues. Any suggestions to source them? |
Geo
Wichitabub ![]() Newbie ![]() Joined: May-20-2021 Location: Wichita Kansas Status: Offline Points: 22 |
Thanks for the information,it’s appreciated
MourningWood ![]() Gold Member ![]() Joined: June-13-2014 Location: NorCal Status: Offline Points: 920 |
The blower can be found above the fuel tank
'I measured twice, cut three times, and it's still too short!" |
Bob,
Before you condemn the blower, get the VOM (volt Ohm Meter) out and do some checking. Start at the switch to see if you are getting the volts out of it. Maybe it's just the switch? You should have the combination breaker/switches and they are known to go bad.
I need the location of the bilge blower, I’m sure it needs to be replaced,because when the switch is turned on,nothing happens. Thanks Bob in Wichita
