  New Posts New Posts RSS Feed - 1985 CC Trailer repair
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Topic: 1985 CC Trailer repair
    Posted: August-02-2021 at 12:12pm
*outer bearing
Spindle is the same on 5200/6000 lb axle… just the outer bearing/hub is different.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: August-02-2021 at 11:10am
This thread is also loaded with 89 trailer info which may match your 85 6-lug. I’ve heard somewhere there are 2 size drums/hubs which could impact the OD of your inner bearing.
https://www.correctcraftfan.com/forum/forum_posts.asp?TID=16419&title=89-correct-craft-trailer-repair
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morfoot Quote  Post ReplyReply Direct Link To This Post Posted: August-02-2021 at 6:04am
 NAPA Part #'s included in this thread along with a couple of other links
Replacing trailer bearings on my 1988 - CorrectCraftFan.com Forums - Page 2
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: August-01-2021 at 11:54pm
Take the old bearing and races to a good auto parts shop -- like NAPA.  They should be able to help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: August-01-2021 at 10:02pm
If you have 6 lugs you have a 5200-6000 lb package
Wouldn’t hurt to measure what you got and compare to what you get.
GeoB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GeoB Quote  Post ReplyReply Direct Link To This Post Posted: August-01-2021 at 7:36pm
Hi, new to forum. Just found the trailer for an 85 SN that I purchased on a lake.
Hubs leaking.
I pulled bearings and seals   I’m looking at parts online and can not ID the parts needed.
What weight was this trailer built for?
Kits are listed as 2,500-3,500 or 5,200-5,000 pound trailers.
Geo
