Goop on screws |
gun-driver ![]() Grand Poobah ![]() Joined: July-18-2008 Location: Pittsburgh, Pa Status: Offline Points: 4127 |
![]() ![]() ![]() ![]() ![]() Posted: October-09-2021 at 2:49pm |
What Doc states is correct, but I would not use 5200 on anything you may want or need to remove again in the future.
That stuff is just pretty much permanent.
DrCC ![]() Grand Poobah ![]() ![]() Joined: April-12-2004 Location: at home Status: Offline Points: 2875 |
Yes, goop the screws.
Anything and everything below the waterline. Goop the part and goop the fasteners. I prefer the 3M 5200. And avoid substitutes like Boatlife sealants, It will washout, sometimes less than 3 years. 5200 should be good for well over 20 years maybe more. If your old sealant feels greasy, it's probably a cheap substitute. |
75 Tique ![]() Grand Poobah ![]() ![]() Joined: August-12-2004 Location: Seven Lakes, NC Status: Offline Points: 6131 |
Sealant. Probably 3M 4200. Two common sealants for hull penetrations, 4200 or 5200. The 4200 is sealant only and allows for disassembly. The 5200 is sealant and adhesive and a lot tougher to pull apart. Yes, you will want to reseal all the holes and fittings when you reassemble.
GeoB ![]() Newbie ![]() Joined: July-12-2021 Location: Connecticutt Status: Offline Points: 36 |
I pulled my 1985 SN swim deck and Pito tubes.
What is the white grease goo on the screws and lag bolts? Will I need to replace it when I put all this back? |
Geo
