  New Posts New Posts RSS Feed - Water intake to cooler hose size
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Topic: Water intake to cooler hose size
    Posted: October-30-2021 at 6:03am
Here's a picture copied and pasted from an old thread showing the elbow and the reducer on a mid 80's boat, but yours had the same setup (minus the strainer)
well, I guess that didn't work  Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayoutthere Quote  Post ReplyReply Direct Link To This Post Posted: October-29-2021 at 9:29pm
Thanks keno,
I'll reduce it coming out of the ball valve tomorrow install the 1 inch and order the sure flow.
I've been uploading pictures on another site blue hi lighting everything and clicking copy is how i've been getting pictures over then editing the narrative if need be.
This site is great and there's a wealth of obscure knowledge that would be an otherwise head scratcher.
Only thing i wish i could do is clear out the picture download to make finding the pictures to post easier.
(I deleted my sd card on accident and now have to rename every new picture or the site says that file already exists so copy drag drop click is faster for now).
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-29-2021 at 9:04pm
This is the message that I get when trying to add a new picture
It's like deja vu all over again Wink
Persits.Upload.1 error '800a0006'
There is not enough space on the disk.
/forum/functions/functions_upload.asp, line 171
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-29-2021 at 8:53pm
With a PCM 351, it's 1 inch all the way.
You have the thru hull fitting, a 1 inch NPT 90 degree elbow with a 1 inch to 3/4 inch NPT reducer and then a 3/4 inch NPT nipple screwed into the reducer and a 1 inch ID hose fits on the fits on the 3/4 inch NPT nipple.
I'd post a picture but right now the site won't let me Wink
It says there's not enough disk space
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayoutthere Quote  Post ReplyReply Direct Link To This Post Posted: October-29-2021 at 7:50pm
When i got this boat there was no ball valve and some plastic elbows on the intake, the hose is 1 1/4 but the cooler is 1 inch and so there is also a hunk of hose on the cooler that the 1 1/4 hose fits over.
I want to put the perko sure flow on for flushing between the ball valve and cooler, first thought is to put a reducer on the ball valve and use 1 inch from the intake to cooler i have 3 more feet of 1 inch wire reinforced hose and that will get rid of the hunk of hose that i'm sure didn't come from the factory.
What was there  originally and if reduced, where and how.
The choke point in the transom assembly on alpha bravo volvo omc makes me think reducing it at the intake should be ok but i've never seen 2 different intake hose sizes on inboards, they were always the same size straight thru and out of the sea pump.
Thanks
First test ride yesterday was rained out shooting for sunday at first light
