  New Posts New Posts RSS Feed - Winterizing in central NC
Post Options Post Options   Thanks (0) Thanks(0)   Quote Donald80SN Quote  Post ReplyReply Direct Link To This Post Topic: Winterizing in central NC
    Posted: November-09-2021 at 10:55am
I live near the Charlotte area and I drain the water. I put in STABIL a few weeks ago so it gets a good mix in the tank and fuel system. I also drain the oil and change the transmission fluid via a hand pump.  Later this winter I will do the fuel filter which is due and the impeller which is also due. I have not done antifreeze with my 2002 sport.
1968 Ski Nautique, Project.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morfoot Quote  Post ReplyReply Direct Link To This Post Posted: November-08-2021 at 11:25am
Originally posted by 75 Tique 75 Tique wrote:
I am thinking this year of stabil in the tank as well, as in the spring I have been known to have a gunky carb.
 Yeah, Larry Boy you definately need to add Stabil to the fuel for the 2-3 months you won't use it. An ounce of prevention is worth a pound of cure. Even non-ethanol in a carb for a couple months won't be the best for it. With the boats on my lifts here in GA I don't drain the water out as a norm. I've got bilge heaters plugged in for those nights when it drops below 32'F. Now if we lose power for a couple days then I'll be scrambling to drain a couple blocks.
Faceplant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Faceplant Quote  Post ReplyReply Direct Link To This Post Posted: November-07-2021 at 9:10pm
Looks sharp !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: November-07-2021 at 5:06pm
Originally posted by ultrarunner ultrarunner wrote:
below-grade, essentially
Post Options Post Options   Thanks (0) Thanks(0)   Quote ultrarunner Quote  Post ReplyReply Direct Link To This Post Posted: November-06-2021 at 3:56pm
Originally posted by jimsport93 jimsport93 wrote:
Post that pic Ultra
Most here appreciate a classic inboard
Know I do.
Ok....in my defense, I'm calling this my "rebound boat". Not a rebound I didn't enjoy in my previous life, so I have the same expectation this time Wink
1996 Grand Sport Elite. Same family since new. GT40. 450 hours.
jimsport93 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jimsport93 Quote  Post ReplyReply Direct Link To This Post Posted: November-06-2021 at 3:25pm
Post that pic Ultra
Know I do.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ultrarunner Quote  Post ReplyReply Direct Link To This Post Posted: November-06-2021 at 3:20pm
Originally posted by Jonny Quest Jonny Quest wrote:
Ultra:
We need to see pix of the new boat...
And risk getting kicked off the site?! Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: November-06-2021 at 3:18pm
Ultra:
Post Options Post Options   Thanks (0) Thanks(0)   Quote ultrarunner Quote  Post ReplyReply Direct Link To This Post Posted: November-06-2021 at 11:31am
Yeah, that all makes sense. The seller had planned on winterizing, so I'll let that happen.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75 Tique Quote  Post ReplyReply Direct Link To This Post Posted: November-06-2021 at 10:15am
I am also in central NC, and although its a huge improvement over central NY or Cape Cod or Connecticut, it can still get cold enough to ruin an engine.  Happened to a neighbor of mine.
I dont winterize other than to drain it.  That way, it is always ready for one of those rare, but it does happen on a gorgeous, warm winter day, ski outing.  I am careful about thorough draining, including all ports on engine, and trans cooler.  I am thinking this year of stabil in the tank as well, as in the spring I have been known to have a gunky carb.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ultrarunner Quote  Post ReplyReply Direct Link To This Post Posted: November-06-2021 at 9:58am
Hey gang, for those of you in central NC that store in your garage, do you winterize the motor or just drain the water? I'm going to store the boat in a partially below-grade, essentially heated, garage.
Thanks,
Ultra
