  New Posts New Posts RSS Feed - Temp gauge help needed
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Topic: Temp gauge help needed
    Posted: July-18-2022 at 7:40pm
+1 should peg the gauge.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MourningWood Quote  Post ReplyReply Direct Link To This Post Posted: July-18-2022 at 6:26pm
I think you can take the wire off the sender and hold it to a ground with the key on. It should cause the gauge to move. If it does, that may point to a bad sender.
Run View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Run Quote  Post ReplyReply Direct Link To This Post Posted: July-18-2022 at 3:03pm
My 1990 Ski Nautique 351 Ford Windsor temp gauge has stopped working.  If I jump the terminals the gauge pegs so appears to be working.  What could be wrong?  Temp sending unit?  Wiring connection?  How do I resolve?  Thank you.
Run
