8 mm spark plug wires for HEI distributor |
uncle-buck
Senior Member Joined: June-14-2004 Location: United States Status: Offline Points: 327 |
Posted: July-25-2022 at 12:14pm |
I don't recall. They are the standard wires for the PCM 351W engine purchased from SkiDim and converted for HEI. I used them a couple of times and then bought some cut-to-length MSD wires.
gun-driver
Under the manifold length?
uncle-buck
Set of black 8 mm wires for HEI distributor. Less than 5 hours on them.
$25 shipped P.S. One of the spark plug boots was sliced by mistake when converting the wires for HEI. It has been taped and is probably fine, but you might want to replace it. |
