  New Posts New Posts RSS Feed - Transmission seal leak?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ultrarunner Quote  Post ReplyReply Direct Link To This Post Topic: Transmission seal leak?
    Posted: August-01-2022 at 1:27pm
Yeah, this is strange. I'll get a few towels down and check the fittings. Dipstick oil is nice and clean.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: August-01-2022 at 10:50am
Maybe you  have some emulsified engine oil dripping out of the engine Wink
A leak doesn't make that milkshake appearance unless it was coming out already looking like a milkshake.
Take a little oil or ATF and drip it into a little water, it won't look like your picture unless you shake it up pretty good to get it mixed.
pjsmoreno View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pjsmoreno Quote  Post ReplyReply Direct Link To This Post Posted: August-01-2022 at 10:05am
Mine was nice and red when my front seal leak a few years back.....not  strawberry color on the bilge.
Fl Inboards View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fl Inboards Quote  Post ReplyReply Direct Link To This Post Posted: August-01-2022 at 9:08am
Pretty easy? check your trans fluid/oil level. provide water engine cooling source, start engine bring to temp. shut off engine.
 Grab clean white rag, and lay it flat under bell housing in the bilge, Front transmission seal /  engine rear main seal area .
Take second white rag lay flat under transmission tail housing, Rear transmission seal.
Take third rag lay flat under oil pan drain kit fixture.
Take third white rag and wipe all the high pressure fluid hose connectors, check for fresh fluid.
Go have beer, or what ever for an hour or so.
Come back check rags and assess info on rags..
Post Options Post Options   Thanks (0) Thanks(0)   Quote ultrarunner Quote  Post ReplyReply Direct Link To This Post Posted: August-01-2022 at 8:54am
Looks to me like it was kinda emulsified before it leaked out of the transmission like Mpost suggested.
Nice and red on the dipstick. I think a bit of residual water in that groove in bilge. I guess I'm pulling the trans. this fall :-(
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: July-31-2022 at 6:13pm
+2 when my case gasket let go it was nice red oil there LOL no strawberry shake
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: July-31-2022 at 3:49pm
Mpost View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mpost Quote  Post ReplyReply Direct Link To This Post Posted: July-31-2022 at 8:12am
? is that dripping white or mixing with water in the bilge???? Water in the oil making it overfull?
84 SN Sold   98 SN    Lund Pro V   1975 Alumacraft
Post Options Post Options   Thanks (0) Thanks(0)   Quote ultrarunner Quote  Post ReplyReply Direct Link To This Post Posted: July-31-2022 at 8:08am
Getting a slow drip when static. Transmission seal?
