  New Posts New Posts RSS Feed - Isolater Bushing Transmission Mount
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Topic: Isolater Bushing Transmission Mount
    Posted: October-12-2022 at 2:15pm
At least your getting a song Ken - all I have is my tape on fire as it self destructs Shocked
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-12-2022 at 1:38pm
Always learning Thanks. Didn't realize you could put in part numbers- probably one of the updates to their site when they upgraded. Now help me find a manual or parts diagram for an Indmar 140 Wink. It's like they don't exist
I keep hearing the theme song from Mission Impossible in my head, but I can try Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: October-12-2022 at 11:29am
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-12-2022 at 5:23am
Who says they're not listed
 Now Ken I knew they had them and even looked- but nothing came up. Did you search by part number?
At the top of about every page on their website it says "what part do you need today?"
I put the PCM part number in there
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: October-11-2022 at 11:19pm
 Now Ken I knew they had them and even looked- but nothing came up. Did you search by part number?   As long as you know what you want or even have PCM's part number they can order since they are a PCM dealer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MourningWood Quote  Post ReplyReply Direct Link To This Post Posted: October-11-2022 at 9:35pm
Recently did this job on a '94-same mount.  Much, much easier with the entire mount out of the boat and on a workbench. Winter is coming-you have the time...
marksa1458 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote marksa1458 Quote  Post ReplyReply Direct Link To This Post Posted: October-11-2022 at 6:08pm
I ordered them!  Appreciate the part numbers
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-11-2022 at 5:15pm
Who says they're not listed?
link to clip
link to isolator
Post Options Post Options   Thanks (0) Thanks(0)   Quote marksa1458 Quote  Post ReplyReply Direct Link To This Post Posted: October-11-2022 at 4:48pm
Thanks for the quick reply - I will reach out to SkiDim and get the parts ordered.
So -
*loosen the trunion bolts
*reposition the mount
*install the new bushing and clip
*Tighten the Trunion bolts
*Alignment
*Go Skiing
Is that right?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: October-11-2022 at 4:09pm
Skidim does have the parts but you'll have to call them they are not listed. The rubber part is called an isolator PCM part number R094004 and lists for like 3.00.  And it looks like your missing the clip. Snap ring R017032 thats under a 1.00. Might be a good idea to check your alignment when your all through as well something has shifted.
Post Options Post Options   Thanks (0) Thanks(0)   Quote marksa1458 Quote  Post ReplyReply Direct Link To This Post Posted: October-11-2022 at 2:31pm
Was winterizing a new to me 2000 Ski Nautique with the PCM 5.8 HO engine. The driver's side transmission Isolater bushing has worked its way out of the mount:
What is the repair for this? I can order just the bushing from Ski Dim or I can order a whole new Transmission mount -
There is no vibration in the driveline at any speed/rpm and there is no movement on the mount if throttle is applied.
The passenger side mount looks like this:
Thanks
