What engine part is missing from my 04 210? |
KENO ![]() Grand Poobah ![]() Joined: June-06-2004 Location: United States Status: Offline Points: 11247 |
![]() ![]() ![]() ![]() ![]() Posted: October-24-2022 at 6:40pm |
That black circular thing that's leaking oil is the hole for the pushrod that would drive a mechanical fuel pump.
If it wasn't drilled out, it would look like just a piece of cast iron with no hole. Yours looks drilled out and the little hole below it is the oil return to the oil pan. Since you have a hole that will let oil leak out and you don't have a block off plate, you should get a block off plate like in the link below That's just one example, they're easy to find and cheap and will stop that leak of yours ![]() An 04 Excalibur with that hole makes me wonder if your engine was rebuilt at some time before you got it, and an older style block was used and nobody put a plate there since the original 04 probably didn't have one (just an opening to nowhere, with neither hole drilled so GM skipped the plate)
TRBenj ![]() Grand Poobah ![]() ![]() Joined: June-29-2005 Location: NWCT Status: Offline Points: 21210 |
Cover for the fuel pump boss. Not likely it’s drilled anyways, probably not critical.
darbyglen ![]() Newbie ![]() Joined: December-01-2015 Location: Durham, NC Status: Offline Points: 9 |
When I was winterizing my 04 120 w/ the PCM Excalibur over the weekend I finally pulled out the hard tanks to get a better view of a small oil leak that has been occurring since I bought this boat a few years ago. Upon inspection of the lower rear port side, I noticed this area that looks like it is missing a part based on the bolt pattern and what may have been a gasket at one point in time. At idle, I noticed a small droplet of oil spitting out of the large hole. As I give it more gas, the oil volume increases a little bit. What goes here? (The picture should be rotated 90 degrees clockwise but I'm not sure how to do that here) ![]() |
