Exhaust flex hose |
norrisdam
Newbie Joined: August-26-2013 Location: Ohio Status: Offline Points: 36 |
Posted: June-12-2023 at 5:25pm |
The hoses and mufflers were replaced because of age. They were original.
He did not remove the 90 degree elbows but I will bring it to his attention as well as the other items. Thanks for the reply.
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11115 |
Thanks(1)
Were the hoses and mufflers replaced due to heat damage? The elbows should be removed and checked and the inlet hole they thread into should also be checked. Since it does it more while idling I'd also verify that your suction strainer if you have one isn't letting air in due to a bad O ring or loose housing and check the inlet to your transmission cooler for any blockage, especially if you don't have the suction strainer. Any air leak on the suction side of the pump will affect it's ability to suck water especially at low speeds, so a double check on the hoses and clamps couldn't hurt Temperature being good when running on the hose but running hot when sucking from the lake points toward a suction side air leak that's overcome by the assist from the hose If you had to replace an impeller recently. check the inlet to the pump for old impeller pieces. They can get stuck there too along with getting stuck on the outlet side. |
Jonny Quest
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2979 |
Smoking and hot exhaust hoses is a symptom of a cooling system problem. Your cooling system is designed to have raw water and exhaust mixed in the exhaust manifold/risers and exhaust hose. I would check for proper water flow into both manifolds/risers.
norrisdam
I have a 1986 Martinique and just had the mufflers and exhaust hoses replaced.
I noticed after running the boat for awhile that the new exhaust hoses will start heating up enough to start smoking with a burnt rubber smell. It seems to be more noticeable when idling. The engine temperature gauge was normal. The mechanic has checked all the water hoses and they are ok. He also has raised the boat out of the water so a garden hose could be attached to the strainer assembly and it ran fine without heating up. Any ideas on fixing this problem?
