  New Posts New Posts RSS Feed - Need Prestolite RR
Need Prestolite RR
Mille1sj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mille1sj Quote  Post ReplyReply Direct Link To This Post Topic: Need Prestolite RR
    Posted: June-21-2023 at 9:39am
DO you know what the shaft diameter is for your distributor?  I have composite gears for the Ford 302 with a .467 shaft diameter but they can be opened up to fit the 351 with the larger diameter shaft.
brentimel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brentimel Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2023 at 11:34am
I need the RR gear for my 351 Commander.  Wanted to restore it to points ignition and the gear got broken removing it.  Any help would be appreciated.
