Need Allen size late 90's thermostat housing |
Author | ||
iflooru ![]() Newbie ![]() Joined: February-20-2021 Location: Cleveland Status: Offline Points: 5 |
![]() ![]() ![]() ![]() ![]() Posted: June-22-2023 at 1:32pm |
Thanks all! Gotta chase me down some impeller pieces parts this weekend.
cbr1000dude ![]() Senior Member ![]() Joined: August-23-2011 Status: Offline Points: 330 |
My tools are all over the place, it's a disgrace. So I use whatever I can find at the moment. Sad
KENO ![]() Grand Poobah ![]() Joined: June-06-2004 Location: United States Status: Offline Points: 11222 |
5/16 and 8 mm are about as close as you can get size wise. 5/16 equals .3125 inches 8 mm equals .3149 inches so .0024 inches difference You can fit an 8 mm allen wrench into the socket head that's made for a 5/16 allen wrench, but why not just use the 5/16 Kinda like your 6 mm allen wrench that you used on the Ford bolt made for a 1/4 inch wrench. A little sloppy but it worked ![]() |
67 ski nat ![]() Platinum Member ![]() Joined: July-19-2018 Location: Santa rosa Status: Offline Points: 1199 |
Take all your tools
I did not know that! I'm a Ford guy and assumed he was too,So 8 mm will work?
But, but ,but .......he has a Chevy and what worked on your Ford will be a pretty sloppy, loose fit on his bolts.
They're bigger diameter, 3/8-16 threads and they take a 5/16 allen wrench |
6mm worked for me today on a 1990 sn
But make sure one of those tools is a 5/16 allen wrench
If I was you
Take all your tools |
Couldn't get a hex socket on it, height issue, and didn't have any L shaped ones with me. So want to make sure I have correct L key when I head to cottage this weekend.
Is it a 5/16ths or metric? Thanks George '99 Pro Air with the Apex |
