1998 ski nautique parts |
Orman
Groupie Joined: July-07-2014 Location: waverly Status: Offline Points: 42 |
Posted: October-08-2023 at 9:01am |
It needs to have trim tab.
andrewmarani
Senior Member Joined: May-31-2005 Location: Baltimore, MD Status: Offline Points: 249 |
Not too hard to post images. First time usually is a learning curve but once you've done it once, gets easy. Common Questions / Adding Images.
Builder
waterwrench
Groupie Joined: July-16-2014 Location: iowa Status: Offline Points: 52 |
Yes i have some pictures. There jaw dropping pictures. Not sure how to post pictures on here, or if its even possible.
waterwrench
Yes i still have the rudder. Is not damaged.
Orman
I am looking for a rudder for a 98. Is the rudder damaged? This is for the following models:
196 1995-2009 206 1995-2009 216 1995-2010 211 2004-2010 220 2006-2009 236 2007-2009 200's 2010 on Up |
workky
Senior Member Joined: June-26-2004 Location: Marietta,Ga Status: Offline Points: 206 |
OMG!!!!
NCH20SKIER
Grand Poobah Joined: December-16-2004 Location: United States Status: Offline Points: 2207 |
Any pictures - before / after?
'88 BFN |
waterwrench
It went thru the dam and was ripped into 2 pieces.
What happened to the boat? Is it whole-ish currently?
waterwrench
Complete exhaust system minus manifolds. Will sell all or part , Fuel tank , tank mounting hardware , trany cooler , bellhousing , damper plate , flywheel for GT-40 engine. Aluminum engine cradles intake manifold , fuel injectors.
