  New Posts New Posts RSS Feed - Key buzzer alarm going off while engine running
Live2fish View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Live2fish Quote  Post ReplyReply Direct Link To This Post Topic: Key buzzer alarm going off while engine running
    Posted: March-15-2024 at 4:02pm
The jumper that goes from the water temp to the oil switch came loose and that was causing the alarm đź‘Ť we are runnin smooth now!
Post Options Post Options   Thanks (1) Thanks(1)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: March-15-2024 at 8:42am
In 81 CC didn't have a warning system like that, maybe it was added, maybe it's a later engine.
Since you mention an oil pressure switch which is really close to where you were working to put the new fuel pump on, I'd check that switch.
With a multimeter, the switch should be closed when the engine is Off .and when the oil pressure is above about 5 psi when the engine id running, it'll be open
With the switch closed, when the key is turned to the Run position the alarm sounds because there's no oil pressure, then when you start the engine and pressure comes up, the switch opens and the horn stops making noise.
There's probably also a water temperature switch that's open whenever it's below 200 ish degrees.
Here's a link to a thread with some troubleshooting info  on what CC used in the 90's, your setup may be similar
PS ................read the section on posting pictures in that thread too  Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Live2fish Quote  Post ReplyReply Direct Link To This Post Posted: March-14-2024 at 6:28pm
So my 81 351 buzzer started going off all the time where it use to turn off once the engine started. What sensors does this engine have that would turn the buzzer on? Started buzzing after replacing fuel pump and rebuilt carb. Not sure where to check.
Oil pressure switch and sensor are on a T fitting next to oil filter.
(Checked terminals seem fine) what should they test at if good?
Oil pressure is showing around 60 on the dash when cold dropped down a bit when it warmed up before. Haven’t run it long enough to warm up since the buzzer stayed on
oil level good
Water pumping out the exhaust
What should I look for?
Thanks
