  New Posts New Posts RSS Feed - 75 SW  speedometer
75 SW speedometer
Tomrupp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tomrupp Quote  Post ReplyReply Direct Link To This Post Topic: 75 SW speedometer
    Posted: April-05-2024 at 12:50pm
Thanks for posting Den Den. I thought you posted some hardware, a 3 ball and a shark tooth for some reason. I understand now that I have seen each picture.
Tom
94 Ski Nautique Open Bow 351 with Carb
95 Double Decker Aqua Patio with 50hp Honda (3 carbs).
DenDen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DenDen Quote  Post ReplyReply Direct Link To This Post Posted: April-05-2024 at 10:31am
When I got the boat, Speedometer worked just fine. I planned on hooking it up as it was except I got paint in the tiny little hole the pressure needs to transfer through so I took it out and cleaned it up.
I couldn’t find any posts showing this old Speedometer pick up so I thought I would make one.
It has a 1/8 inch copper line with a flare fitting that goes on the top.
I think it’s pretty remarkable that after 48 years it still works !!!!
best picture resolution for facebook
