Battery recommendation |
63 Skier
Grand Poobah Joined: October-06-2006 Location: Concord, NH Status: Offline Points: 4269 |
Posted: April-11-2024 at 8:36am |
New battery is easy and you were asking about size so I assume you figure you need one. Might as well start there. Or a super simple way to prove that out is to jump your current battery to your car and see if that solves it.
12.0V is a dead battery. Need 12.5V or darn close.
ultrarunner
Platinum Member Joined: October-02-2005 Location: Ridgefield, Ct. Status: Offline Points: 1846 |
All back together, but still fighting the starting issue? WTF! I was fairly certain that bypassing the relay via the alligator clips, to get the starter going, isolated this issue to that solenoid relay? Hmmm...maybe not....had battery on charger all night, and I do have 12 volts, and everything powers on. I double checked the NSS, and while I do need a new connector, it is snug. Thoughts? Ignition sw at the dash?
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11112 |
MrMcD
Grand Poobah Joined: January-28-2014 Location: Folsom, CA Status: Offline Points: 3750 |
I just run down to the local SAMS club and buy my batteries. They are all dated so buy one that is fresh. Take your tape measure with you and you can measure the available sizes to see if there is a better fit for your boat. In boats where the battery gets pounded frequently I have found the batteries with less amps live longer. So instead of buying the 900 AMP battery I will settle for the 650 AMP. The plates inside are not as big so not so close together, they seem to survive a little longer without shorting out in boat service.
ultrarunner
I have a battery box that falls approximately in the Group 35 size, but not quite that tall. I can go a bit taller than my box (7.5"), as I can shim up the cover. Obviously, 9.5" L x 7" W are not negotiable. Any recs on a good batt in this size? No big speakers or amps.
Thanks, Ultra.
